Warhawk Heads
I have 1 bare set of warhawk heads. Part number# 025150 World Products Warhawk 15 degree LS1X Cylinder Heads
Cylinder Head, LS1X, Aluminum, Assembled, 64cc Chamber, 220cc Intake Runner, Chevy 1997-2006 PM me for Pricing.
I have 1 bare set of warhawk heads. Part number # 025250 World Products Warhawk 15 degree LS1X Cylinder Heads
Cylinder Head, LS1X, Aluminum, Assembled, 72cc Chamber, 220cc Intake Runner, Chevy 1997-2006 Pm me for Pricing.
Primarily for street use, ls1X 15 degree heads represents significant improvement over factory style heads. with 220cc intake runners, the heads presents the optimum balance of air flow and velocity. Another key improvement of the warhawk head is the valve centerline and rocker arm attachment are parallel at 15 degrees to assure correct geometry, even with longer then stock valves. made from 355-t6 alloy aluminum, the head has steel intake and hardened steel exhaust seats, bronze valves guides and valve srping seats machined to accept 1.550 springs. Intake valve size is 2.080 and exhaust valve is 1.60 both with 5/16 stems. valves are not included.
I aslo have the LS7X aluminum Blocks
Part # 086515 which is the 9.240 deck and I have the Part # 086525 which is the 9.800 deck. Pm me for pricing
LSX7 bare alum heads
Part # 025350 255cc chamber is 64cc
Part # 025400 255cc chamber is 72cc
PM me for pricing
PM me for pricing
