Virginia Speed Inc. monthly specials-FEB
well Feb is almost here so we decided to get a little jump on it
FAST 90mm intakes -$775.00
Any comp cam-shelf or custom grind-any specs you want-$360.00
Ported ls6 oil pumps-$125.00
All Mahle powerpak piston and ring set-starting at $450.00
Eagle 4340 cranks-$840.00
Eagle H beams-$430.00
Comp cams pushrods-$99.00
more to come
more to come
long blocks on sale
347 alum or 370 iron
stock block fully machined
stock crank
mahle forged pistons
eagle h beams rods
clevite bearings
arp head and main studs
ported heads
custom cam
ls7 lifters
double roller timing set
ported oil pump
comp cams pushrods
stock rockers
$5750.00
for eagle forged crank add $600.00
for ls2 or l92 block add $600.00
available with ls or l92 heads
available for n/a,nitrous or fi applications
stock crank
eagle h beams rods
clevite bearings
ported heads
custom cam
ls7 lifters
ported oil pump
comp cams pushrods
stock rockers
$5750.00
