Introducing The Maximizer From Nitrous Express
We are proud to offer NX's new controller.The Maximizer.
This is the only controller on the maarket with with a built in RPM activated window switch with a gear counting feature,and the first to have a built in TPS voltage sensing switch to activate the system.The Maximizer also has a delay and ramp feature.This unit will ramp up or down for turbo cars,and you can also change the ramp parameters for each gear.The unit will hooks up to your 02s to read the air/fuel ratio and allows you to cut the nitrous off at any given ratio.
This unit is retailing at 650.00.
Order now and be one of the first to get it.
1-866-648-7637
Thanks
Dave
1-866-648-7637
Thanks
Dave
