Holley Billet LS2 Throttle Bodies with throttle bracket
Closed ex-Sponsor Account
Throttle Body Style:Multi-port injection, MPIAirflow Rate (cfm):cfmVenturi Quantity:1Venturi Diameter (mm):90mmTPS Sensor Included:NoIAC Motor Included:NoGaskets Included:NoHardware Included:YesInjectors Included:NoThrottle Body Material:Billet aluminumThrottle Body Finish:Clear anodizedQuantity:Sold individually.Notes:Will also fit FAST intake manifolds. Not designed for drive-by-wire applications. Fits model with a throttle cable only.Throttle Body, Billet Aluminum, Clear Anodized, 90mm, Chevy, 5.7L, Each
Reliability you can count on.
Holley's great looking, high-flow billet LS2 throttle bodies are designed to bolt onto LS2 and FAST intake manifolds and deliver the performance you're after. They have contoured throttle bores for smooth, predictable performance, idle to wide-open; and the throttle shafts run in sealed roller bearings for easy operation. These throttle bodies are equipped with stamped linkage and have a clear anodized finish. A throttle cable, hardware, and installation instructions are included. These throttle bodies will not fit drive-by-wire applications.
PM me for pricing
