NEW PRODUCTS - Volt Booster/Fan Switch/Hotwire Kit
We have tested these products and they have worked phenomenally. The V-Plus Volt Booster is on our 9 second LT1 car and our 711RWHP Turbo LT1. The fan switch is a well engineered kit that is at a great price. The stock wiring for the fuel pump can be inadequate for high horsepower needs... the hotwire kit insures steady voltage to the fuel pump when it needs it the most.
CSP102131 LT1 V-Plus Volt Booster $69.99
CSP102151 LT1 F-Body Fuel Pump Hotwire Kit $69.99
CSP109068 LT1/LS1 Fan Switch $65.99
CSP102130 LS1 V-Plus Volt Booster $69.99
CSP102150 LS1 F-Body Fuel Pump Hotwire Kit $69.99
----Available now on ls1speed.com in the PCM/Electronics Section----
Jon
LS1 Speed
866-LS1-SPEED
www.ls1speed.com
Jon
LS1 Speed
866-LS1-SPEED
www.ls1speed.com
Nevermind found it on your website
V-Plus Volt Booster
Your alternator is designed to put out a specific voltage, generally 13.8 volts. The only problem is when there's a greater demand on the electrical system, such as a WOT blast, the alternator falls a little short. The V-Plus is designed to overcome voltage taper at WOT by stepping up the alternator voltage 2.2v. at 70% throttle. Result? More power to your fuel pump and ignition system. Unit plugs in, with no wires to cut or tap into. Includes hardware
V-Plus Volt Booster
As long as Racetronix is using the same factory electrical connector, it will plug right in.
The hotwire kit also includes an extra harness for inline pumps.
TOm
www.ls1speed.com
TOm
www.ls1speed.com
