cam install special
lsx motorsports is now open in kenner,la so to kick off our grand opening we are running a a cam install special.
comp cam any grind
dual springs up to .660 lift or single 918 springs up to .600 lift
titanium retainers
new valve seals and spring seats
hardened pushrods
arp cam sprocket bolts
arp cam retainer plate bolts
new water pump gaskets
front cover gasket
crank seal
new crank bolt
6qts of mobil 1 5w30 synthetic oil
a/c delco pf 46 oil filter
coolant
$1350 installed
call to schedule an appointment
lsx motorsports
2201 aberdeen st suite a
kenner,la
504 906 9553
comp cam any grind
titanium retainers
hardened pushrods
front cover gasket
crank seal
new crank bolt
coolant
$1350 installed
lsx motorsports
kenner,la
504 906 9553
When is this deal good for? Is it the same price for both springs? I think it would be worth the drive from lafayette. And how long would it take to install and are you open on Saterday?
they are real good and will not take long with your car they put a cam in mine in one day drop off in the morning and pick up in the evening. nick and rich are real good people. good luck with more cam install specials.
