BAER Tracker tie rod ends / bump steer kit
Hey guys, I've got an extra set of Baer tie rod ends up for grabs. Retail 165.99 These are brand new in the package and you can have them for $115 plus shipping.
Understanding bump steer:
Lowering a vehicle or altering its caster and/or camber can lead to unsafe driving conditions, commonly called "bump steer." Simple maneuvers, such as hard braking, cornering or traveling over road-surface irregularities, can cause the vehicle to dart in an unexpected direction.
Baer Trackers™ solve this problem! The pin-height-adjustable tie rods allow compensation for ride height and suspension geometry changes, enabling a more optimal range of articulation between the tie rod and
the steering arm. Steering geometry is optimized and
bump steer is eradicated.
(To adjust the tie rodheight, simply move the steel
spacers from one side of the spherical bearings.)
Just give me a call
Jesse -ext 358
- Hardened chrome-moly pins
- Teflon-lined chrome-moly spherical bearings
- Aluminum sleeves
Just give me a call
Jesse -ext 358
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
bump!
__________________
