6.0L GM engines with L92 cylinder heads!!
LS1TECH & TRUCKS Sponsor
Just received! New, direct from GM, 6.0-liter engines with L92 cylinder heads.
6.0L LS2 Aluminum Blocks
L92 Cylinder Heads
L76 (Car) Intake Manifold
Complete Engine – fuel rails, throttle body, ignition coils, flexplate, water pump, factory exhaust manifolds, plug wires, and spark plugs
Choose your T/B design (drive by wire or cable), 24X or 58X crank. Oil pan is front sump design and can be changed for an additional charge or you can install your pan and pick-up assembly. Limited supply!
$4895.00 --- includes shipping in the lower 48-states.
Thanks!
L92 Cylinder Heads
Thanks!
LS1TECH & Trucks Sponsor
Around 385.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
