The Powder Pro powdercoated brake caliper,ported throttle body,and MAF exchange!
Old 09-07-2008, 05:44 PM
  #61
c5formula's Avatar
just ordered a P&P throttle body an maf ends for my 99 z28 today!
Old 09-08-2008, 08:22 AM
  #62
Motorboater
SilverGhost's Avatar
shipping out today, thanks!
Old 09-09-2008, 10:09 PM
  #63
Motorboater
ok picture time as usual. couple of the items I did for LS1tech members in the last day
Ported throttle body, mirror black body, grey metallic cam gear, super clear topcoat over everything. polished return spring and IAC motor of course
Hood latches and bolts/nuts in my custom NBM match
Old 09-14-2008, 08:40 PM
  #64
Motorboater
Just did these this afternoon for a tech member.
mirror red calipers, mirror black brackets
Old 09-16-2008, 08:27 PM
  #65
02SOMLS1WS6's Avatar
Those look extremely smooth...did that member do any sanding to smooth out the calipers or is that just powerder coat doing the work? I am still investigating what calipers I want powdercoated, stock or C5 calipers? I am leaning towards stock because I dont want the raised corvette lettering that is cast into the C5 calipers...although I would rather have the better brake performance you get from the C5 calipers. I might looking into grinding the corvette casting off of the caliper. I hope to be in touch soon and I might be the first SOM customer
Old 09-16-2008, 08:42 PM
  #66
Motorboater
Nope, no sanding. These were a set on my core exchange program, you don't want to know what these things looked like when I got them from the previous customer lol.
I just media blast with aluminum oxide which leaves a really nice surface for the powder and then that really nice smooth look you are seeing on all my calipers is just the beauty of powder coating in action
I was going to say..could grind those letters off, would be some work but not all that bad I wouldn't think. I would prefer you have me do the grinding though if you go that route. If you get even a hair too carried away with the grinding wheel it will create some low spots in the caliper that would take away from the finished product, let me be responsible for that one if it happens lol.
Old 09-16-2008, 09:02 PM
  #67
Actually I was going to ask if you could do the grinding for that very reason. I will get off my butt and make a decision and then I will have you get started. The reason I want the lettering ground off is one I simply dont want them to say vette and two I want you to do the trans am stickers under the clear. I will be in touch really soon. I have a car show mid Oct what is the turn around if I let you know what I want by the end of the weekend? If I do go the C5 route I will probably also send you new spindles (after I look at them and make sure nothing special will need to be done to get them coated) and possibly the UMI brackets (I think these are aluminum though so I might not need to get these coated...maybe clear??). Sorry so long I will be in touch real soon.
Old 09-16-2008, 09:08 PM
  #68
Motorboater
I can get you handled by your show if you get me the parts soon. Just PM me the details, everything you just listed won't be a problem to accomplish. Can grind the letters off and do the trans am stickers and the other parts you wante coated too.
Old 09-24-2008, 12:11 AM
  #69
bdg7884's Avatar
So what does porting your maf ends do? Also how many different colors do you have? I will probably be ordering tb and maf ends within the next day or so ! Hopefully I can get my calipers done next spring.
Old 09-24-2008, 12:21 PM
  #70
Motorboater
Porting a MAF removes all the factory restrictions and significantly increases airflow, same concept as porting a throttle body or anything else really
Color wise I can do anything
PM with what you'd like, be glad to help..
Old 09-24-2008, 01:11 PM
  #71
k0261886's Avatar
How much would it be to have the actual rotors them selves powder coated black? Could you give me a price shipped, my zip is 49245. Thanks
Old 09-24-2008, 01:31 PM
  #72
pwterz28's Avatar
that engine cover looked bad ***. how much for to do one in the same colors
Old 09-24-2008, 04:23 PM
  #73
Motorboater
i'll pm both you guys now
Old 09-24-2008, 08:19 PM
  #74
cdoggy81's Avatar
How much does rebuilding the calipers add to the cost?
Old 09-24-2008, 09:46 PM
  #75
Motorboater
If you want brand new seals/botts/slider bolts on the calipers when I put them back together after powder coating them that's no problem. I can get the rebuild kits on discount from a local dealer. Its like $90 normally, with my discount its about $60 for all 4 instead.
Old 09-24-2008, 10:40 PM
  #76
cdoggy81's Avatar
So $265? Sign me up
Old 09-24-2008, 11:19 PM
  #77
Motorboater
i'll send you a PM now..
Old 09-26-2008, 11:41 AM
  #78
cdoggy81's Avatar
Got it & thanks. It should be a few weeks & then I'll send them out.
Old 09-26-2008, 09:02 PM
  #79
Blksilvr's Avatar
SilverGhost , do you have any Black Chrome or Anodized Blue over reflective chrome powder ?
Thx
sent you PM also
Old 09-26-2008, 10:37 PM
  #80
Motorboater
Sounds good Cdog
replied to your pm blksilvr. I have the anodized blue and chrome powders in stock, yes.
Quick Reply: The Powder Pro powdercoated brake caliper,ported throttle body,and MAF exchange!
