New Speed Inc. Twin Turbo 408ci dyno results
Speed Inc has a large portfolio's of custom turbo systems built on late model domestic vehicles. Dipping into the 8's in the 1/4 mile and speeding above 199mph in a standing mile. Built around efficiency and dependability, these vehicles can be driven regularly on the street. Advancements in dual stage fuel injection, large high impedance injectors, 3-bar programming for factory PCM's, and adaptable after market PCM's have helped each project obtain awesome power results while not being a 'race car'.
This is the latest turbo vehicle to roll off the dyno at Speed Inc.
Engine:
Turbo System:
Dyno runs were made through a T400 trans and 12bolt rear end.
Engine was pulled to 7,350.
16psi boost- 826rwhp
18.5psi boost- 882rwhp
Engine:
- 408ci LSx Motor (Iron block)
- 234/234 @.050 113lsa Camshaft
- Patriot Cylinder Heads
- GM LS6 Intake Manifold
- Stock LS1 Throttle Body
Turbo System:
- GM Truck Exhaust Manifolds
- (2) Precision PT67 P-trim Turbos
- (2) Tial 38mm Wastegates
- 50mm Tial BOV
- Dual 3" downpipes
- 4" Single exhaust
- Magnaflow Muffler
- Hot Side - High Temp Black Ceramic Coating
- Cold Side - Gloss Black Powder Coating
- HPTuners 3-bar OS
- (2) 255L Walbro Fuel Pumps
- RC 75# High Impedance Injectors (66psi base pressure)
