dlove's 414 Powered 00' Z28
#61
I found what did my motor in. The vvt oil pump.
Found a spun bearing in the bad cylinder. Looks like I probably sucked the pan dry.
The extra slop in the rod cause it to come up more in the cylinder and hit the valve.
Total damage:
1 broken valve
3 bent valves
1 missing piston
1 piston broken off the rod
2 bent rods
2 cylinder sleeves with chunks missing
cracked block
camshaft scored on a few lobes
both heads need lots of work
windage tray bent
Crank scored up
Total damage:
1 broken valve
3 bent valves
1 missing piston
2 bent rods
cracked block
windage tray bent
Crank scored up
#69
cool combo! I grenaded my cam only car a couple years ago like that. I never really figured out why it grenaded though, I know the valve head broke off and went piston to head a few times and that caused the piston to bust in a million pieces and fall down into the crankcase and take out a few more rods. The block was completely destroyed, you couldnt even put sleeves in if you wanted to. But the cam/springs/lifters/pushrods were all fine, I even built another motor with them!
+1 for LSX coffee tables!
