Led flasher
once i get this i will post pics and tell you if it is a good one or not.
i have bought the EL 12 flasher for the blinker and hazards. my lights do not work unless i put a filament bulb in either both the front right and left socket.
I have an ordinary electronic flasher and have switched back and forth between LED and incandescent bulbs without changing the flasher. I got the flasher originally to support my sequential turn signals. I tried LEDs and found I hated the look so I went back to regular bulbs.
ed
Black don't confuse yourself! the sequencial tail lights have nothing to do with it. I personally wanted it to flash slower so I opted for an adjustable electronic flasher ( a modified 555).
PLAIN and SIMPLE your leds do not place enough load on your EL12 to flash, so they just stay lit. Would a EL12 from a different manufactor work? Maybe.
but a true electronic designed for 1 to X bulbs will.
WhiteBird check this out;
https://ls1tech.com/forums/appearanc...-problems.html
Last edited by blackodium; May 28, 2009 at 06:34 PM. Reason: can's make complete sentences lol
ed
I too am relating my personal trials and experiences and I also have a sequencial turns. Mine worked also but I wanted them to go slower for the effect. That's when I started disassembling the flashers to put a variable resistor in and I found out that all supposed electronic flashers are not created equal.
See this post:
https://ls1tech.com/forums/appearanc...aillights.html
Check out this video see how I slowed the rate down.
http://www.youtube.com/watch?v=1uwLRWqmflw
