Driver's side window fix w/o express down
My driver's side window motor is now the slow poke. I want to do this mod to my driver's side, express-down elimination preferred (my e-down has not worked for the past year or so, and i'd rather not have it return). If I were to buy another passenger side module from autotrix, will I see a similar boost in my driver's side window performance like I saw on the pass side? Or is the fault within the module itself?
So I bypass the express down module as you described and the autotrix kit for the passenger's side is plug n play on the driver's side?
it's that or get a new module but they arent cheap.
Can somebody point out in this diagram precisely what to do?:.....
I installed the passenger side kit in both doors and eliminated the thermal resistor in both motors. My windows rock.
*removed brown wire 341 frm s208 to module (c on module)
*removed blue wire 164 frm s263 to module (a on module)
*spliced grey wire 1136 (e on module) to brown wire 165 (d on module)
Now you can essentially plug n play passenger side Autotrix kit EXCEPT the brown and blue wires you splice into no longer come from the switch, they come from the bypassed edm throught the door grommet. You will also need to determine your own routing for power and ground, I just spliced into power I had already installed on passenger side kit. You will no longer have express down but the window works so much better you probably won't miss it.
eta: now that I'm thinking about it, I suppose you could tap into the motor power wires where they leave the edm, I was already in the door to replace the motor so I just tucked the relays into the bottom of the door but the relays could be installed under the dash.
eta again: looking at diagram, you should be able to bypass edm just by cutting gray wire from switch and connecting it to brown wire to motor, then the autotrix kit would be plug n play (or possibly unnecessary since the edm is no longer limiting voltage) I didn't do it that way but if you are feeling brave you could give it a try.
I don't know what you mean by "a short and power" - power is good, a short is not.
The ONLY tough part of all of this is figuring out where to stuff the relays in the door so that they fit and dont rattle around while driving!!
