help installing front speakers RBC-6
I bought the stage 1 package from sparksai over a year ago because my sail panel speakers were blown. This is the link to the speaker package https://ls1tech.com/forums/stereo-el...rksai-com.html
I replaced the subs at the time but held off doing the front speakers until I had to do the window motors. Has anyone installed the Soundstream 3 Ohm RBC.6 before? They work fine but they don't fit in the plastic mounting frame. I was thinking about just getting longer screws and seeing if it will fit ok sticking out a bit, but I figured i'd ask if anyone has a better solution first?
http://www.flickr.com/photos/75658821@N06/
I ended up picking up some #6x3/4" sheetmetal screws and #8 washers to mount the speaker. I had atleast 1/2" between the speaker and the door, so I added 1/4" nylon spacers to support the speaker better. The tweeters fit perfect without any modification.
