Turn signals not working after led install. I even tried
so i changed all my lights to leds. I got 2375r bulbs for the rears they say that there compatible with 2057’s i got them in read only because they didnt have white the fronts are the 3157’s there correct i even tried my blinkers after i changed out the rears. I went and got turn signal flashers today and flasher installed them they still do not work the flashers i got say for incodecsnt bulbs and leds so i think i got the right ones. Everything else works fine. When i put the blinkers on they light up and dont do anything til i turn them off. Any ideas
Ungrounded Moderator
You got the right bulbs (assuming you meant 2357 rather than 2375). They should be red in the back - you should always install LED bulbs that are the same color as the lens they are behind, otherwise your lights will look washed out (pink rather than red).
You didn't get the right flasher. The one you got will work if you replace only half the bulbs (the fronts or the rears). When you replace all of the bulbs front and rear, you need a "no load" LED specific flasher. The Keep It Clean FF552NLF seems to work well on f-bodies... $15 on Amazon.
Thats what i thought i took the flasher back today after work and told the guy at the counter my problem as soon as he saw the flasher he said ya that wont work. He didnt have the right one so i went to autozone he said he could order me one and it was lime $35 bucks i said bo i can order one for $9.95 and the one for the hazards is like $12.95 so i ordered them already so ill wait to see what happens
