What kind of bulbs are these?
Old 10-13-2018, 02:42 PM
5.7stroker's Avatar
Default What kind of bulbs are these?
I have no idea what kind of HID kit is in my car and one of the low beams is out. The headlight housings look like these.
Low beams are standard 55w H1 bulb? Is there a better HID kit that I can use to replace this? The housing is very specific and the bulb is held with a latch mechanism which also serves as a ground. If you put the bulb in the housing and don't fasten the latch over it, it won't light up. I'm assuming the aftermarket kits like Morimoto run the ground a different way? I was Looking at the Morimoto H1 XB HID kit, 55w, 6500k, HD relay but would it even make a difference with these crappy housings?
Amazon Amazon
Old 10-14-2018, 02:33 PM
SparkyJJO's Avatar
H1.
H1 HID bulbs will have both wires to the bulb so you'll not have any ground issues.
I had those housings with HID in my old 98, and they weren't bad. I would NOT run 55W HID in them though, you'll burn stuff up. 35W is the highest I'd go.
Old 10-22-2018, 03:30 PM
EnergyCC's Avatar
Originally Posted by SparkyJJO
H1.
I've been running 55 W HID bulbs in those housing for 3 years now. No problem.....
Old 10-22-2018, 03:32 PM
EnergyCC's Avatar
https://www.youtube.com/watch?v=5R2sBzkxDzQ
https://www.amazon.com/GE-Lighting-H.../dp/B000UHFO8Q
I've had the Morimoto kits and they're good. But they still eventually fail... I've been buying Xentec kits. Much cheaper and I can replace them four or five times, if they fail, for the price of ONE Morimoto kit.
Right now, I'm running a Xentec H1 hid kit in 6K color and they look great in those Spyder headlights.
