6 AWG connector?
6 AWG connector?
Hi,
I have a 750 watts power inverter and I need to use #6 AWG if the power source wire is going to be longer than 4ft.
However I would like to make the power inverter removable so I need a connector that connects and disconnects and uses #6 AWG size.
Does any stero shop or place online have a connector that uses #6 AWG which I can get?
STF Veteran
You'll have to use a mil-spec connector. We use them here at NASA, are they are costly. They also require a special pneumatic crimper for the contacts. You could use #6 lugs and mount each end to a terminal strip and disconnect it from there if need be. Check Newark Electronics 1.800.2.newark or www.newark.com and inquire about the Amphenol lineup.
Thanks for the idea, I found this last night on the web, what do you think?
To save space this is a smaller version of Moroso No. 74200
Will connect up to 50 amps, using #6 wire
Instantly connects your vehicle’s electrical system to an auxiliary power source, either to start the car or for fast battery charges
Also useful on tow vehicles and 4 x 4’s as a power plug for winches, jumper cable connections, or battery chargers
Made of tough polycarbonate with spring-loaded copper contacts
STF Veteran
Originally Posted by Midnight F-117A
Howcome #6 AWG is hard to find? Almost every auto parts and stero store I've been to only carries #4, 8, 10, 12
