new amp
Old 01-19-2005, 12:37 AM
crazymofo1986's Avatar
Default new amp
ok a i got a new 4 chanel amp. i have stock hu, alpine speakers and tweeters, stock mid bass witch im gonna change and stock back speakers that are staying.
should i keep the monsoon amp to jus run the back and add the new amp for the front and mid? or
have new amp run it all? how would i wire it this way?
the stock amp does it has everything already there to plug into the new amp or do i have to buy ne thing or run anything else?
thanks
Old 01-19-2005, 10:11 AM
cjacks7's Avatar
If your are changing the mid bass drivers, just use the new amp on all the speakers.
Old 01-19-2005, 06:50 PM
does it connect to the stock hu no problem?
Old 01-23-2005, 06:06 AM
d james's Avatar
I ran my 4 channel amp the following way. front channels to front speakers, and rears to my sub. this is running off the stock stereo with line convertors, so I left all the rear speakers connected to the stock monsoon and the result is nmot bad, I have to turn the fader more to the back because the new amp is much much louder, and so I turned the fader just enough to provide a rear fill to give extra sound, so its not to loud, and the sub is turned up pretty loud this way I can turn down the bass on the headunit, which means the stokc subs will not push to much and ruin the nice soud-since they sound muddy, this way they produce just a little bit of sound.
