Raptor shift light install: what wires do I tap into??
Need quick help. Need to find out what wires i can tap into for the shift light, and where I can located these wires.
Will be installing in the A-pillar where the side vent is for the side window.
Thanks!
Thanks!
https://ls1tech.com/forums/showpost....7&postcount=54
It's in the sticky on the new user section, there's alot of extremely useful information on there, check out the entire thread sometime. It's good readin'.
Moderator
green to #10 pin on the pcm. Black to ground. Power to Pink wire ( key only power wire) www.installuniversity.com Harland shift light is the same install.
![](http://i3.photobucket.com/albums/y63/dgrundwalski/306e0045.jpg)
Would ya know it, I looked all over installuniversity and couldn't find the darn write up. I knew it was there, just figured it was taken down for some reason.
Okay, has anyone found a way to just run the wires internally rather than tapping into pin#10 outside? I'd rather not punch another hole through the grommet. Already have 2, 4ga wires poking through, and had to seal it off like a **** b/c it leaked like crazy when it rained or washed car.
i found it
http://www.installuniversity.com/ins...ht_install.htm
ok, just about every post in here has this link, thats nice.
Is there a way to not go through the fire wall to the pcm as I described above? Does the tach wire not somehow go to the drivers side cluster somewhere that I can tap into??
What power wire did you tap into over by the a-pillar in your t/a? doing an install now but don't have a multimeter. I know brown wires are supposed to be switched 12volt sources but the one I used isn't working.
Originally Posted by 02NBMSLPSS
You can go behind the instrument cluster and grab the white wire behind the speedo. Thats the easiest way.
The white wire behind your speedo is your tach wire which is also found at the pcm. If you dont want to run the wire outside, this is easier.
Awesome! I wonder why most people just don't do this instead???
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
