Old 04-29-2016, 05:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
How you can add an aux input/mp3 player without an adapter
Old 09-18-2007, 01:01 PM
  #61
Copy & Paste Moderator
VIP1's Avatar
Originally Posted by rmpitzer
Ah....just by receiving a signal from the MP3 player? Pretty cool!
Thanks for the answers!
-Rich
When you push a 1/8" cable into that 1/8" jack, you actually flip the small mechanism inside to switch which which pair of wires is used.
BTW, I edited my previous post with more detail.
Old 09-19-2007, 09:43 AM
  #62
ruquick02ls1's Avatar
Great write up.
I tried this yesterday on my radio out of an 02 camaro and it seemed to work great but the only problem is that i can still hear my cd playing very low in the back ground. Here is what I did.
Pin 1 = ground
Pin 2 = left channel wire to main board
Pin 3 = left channel wire to cd player
Pin 4 = right channel wire to cd player
Pin 5 = right channel wire to main board
Does anyone else that has done this hear the cd playing in the back ground of thier iPod? Please let me know if I did something wrong. Also when I play my cd without the iPod plugged in the sound is very low. Cd player was working fine before.
One more thing I have an AUX for my 12 disc cd changer is there a way to tap into that instead?
Thanks for any help.
Old 09-19-2007, 11:45 AM
  #63
pentavolvo's Avatar
you may have a bad jack if you are getting bleed through and low cd player volume, or a bad connection somewhere, id suspect a bad jack
there is a module to use the 12disc jack on the back but its like 60dollars
Old 09-20-2007, 10:21 PM
  #64
Jason Novak's Avatar
Your wiring looks correct. It could be a bad jack ... the front of the case is clear so you can see the connections being made when a cable is plugged in. If you're able to bench test it you can try touching the mainboard left/right wires directly to the MP3 cable plug. The connections are kind of close together on the jack, make sure the solder or wires aren't bridging across two pins. What are you using as the ground?
Old 09-21-2007, 12:47 AM
  #65
SUX2BU's Avatar
I'm gonna try this too. i hope my HU has the round wires like the camaro HU. I have a 99 TA.
Old 09-24-2007, 01:53 PM
  #66
bdrussell's Avatar
Default Thanks for the help Jason
Originally Posted by Jason Novak
bdrussell:
If you can't hear any sound at all it may be a connection issue, though some of it must be good if the CD player still works. It's possibly the audio cable. If you open it back up check all the connections are good and on the correct terminals. You can try hooking up the ground to the chassis instead.
pentavolvo:
Is that the voice of experience?
I changed the ground to the deck chassis and it works great. Also for what it is worth I made a plate to mount the jack in and used the bolt at the front of the ctr console to mount it on the passenger side, didn't need to drill a hole in any of the cars factory stuff at all
Old 04-06-2008, 07:14 PM
  #67
Cole Train's Avatar
Basically it goes like this, judging from one of the set's of Pictures.
Stereo Jack side {-------------}RADIO Side:
Post 1<------------------------> Ground to Radio Chasis
Post 2<------------------------> Connect to Pin 1 on Circuit Board Side inside Radio
Post 3<------------------------> Connect to Harness Side Of Pin 1 inside Radio
Post 4<------------------------> Connect to Harness Side Of Pin 3 inside radio
Post 5<------------------------> Connect to Pin 3 on Circuit Board Side inside Radio
Maybe that will help. clear things up if there are any doubts. I'm soldering the connector tonight and will add it to the radio tomorrow
Old 04-07-2008, 05:06 PM
  #68
Cole Train's Avatar
well opened up the radio and mine is the Ribbon cable and i can't do **** so i'm gonna just add an aftermarket radio
Old 04-08-2008, 06:46 PM
  #69
Ya, the pre-98 radios have a flat "printed" type cable. It's possible to work with it, but it's much more difficult than the ribbon cables with actual wires
Old 05-19-2008, 11:32 AM
  #70
sandman22's Avatar
Thanks Jason...I did this and it works great. If anyone is wondering where to put the Aux input, I put mine on my TCS control panel. Although I added a little something to make it look better.
Old 05-19-2008, 10:47 PM
  #71
Looks good ... very professional
Old 06-25-2008, 06:35 PM
  #72
bsdoyle's Avatar
Default alright!!!!
ok man soo now i'm on the right thread... thx.... so tell me why you recommend cat 5 cable?? cause its single stranded?? with telephone cable work the same??.. or at least tell me how big of wire (gauge) you recommend
thanks...
DOYLE
Old 06-25-2008, 06:47 PM
  #73
Standard cat 5 is good ... it's cheap and easy to get in different lengths, just cut the ends off a cable. It has more than enough wires, 8 and you only need 5. Telephone wire tends to be pretty thin, and only 2-4 wires.
Old 06-26-2008, 11:40 AM
  #74
z2fast8's Avatar
will this work for a zune??
Old 06-26-2008, 11:58 AM
  #75
Yes, it will work with anything with a standard headphone jack.
Old 06-29-2008, 09:43 AM
  #76
quickchrome2000's Avatar
I was going to use one of those FM transmitters but I'll try this first, this is great info thanks
Old 06-30-2008, 02:47 PM
  #77
98redM6's Avatar
So I don't need to have my cd changer plugged in for this to work or do I? My cd changer crapped out on me a long time ago.
Old 06-30-2008, 03:18 PM
  #78
Nope, it doesn't use the changer audio so it will work fine with or without one
Old 06-30-2008, 07:21 PM
  #79
Ungrounded Moderator
WhiteBird00's Avatar
I think you'll find that you need a changer connected for this to work. The reason has nothing to do with the audio but with the way the head unit won't respond to the CD/Aux button (CD/Play on Firebird) unless it detects a changer attached.
Old 07-01-2008, 12:11 AM
  #80
You don't need a changer for this to work.
It taps directly into the wiring for the internal CD player... WhiteBird00, you may be confusing this thread with the other one where someone was planning on tapping into a connector plugged into the cd changer jack - then you would need a changer for it to work.
You don't set it to aux, you leave it on standard CD player - the stereo thinks it's playing from the built-in CD player but the audio is actually being passed from the mp3 player (until you unplug it, then it works as normal)
Quick Reply: How you can add an aux input/mp3 player without an adapter
