98-02 taillights conversion
Old 04-20-2008, 05:35 PM
JJ93z1SC's Avatar
Default 98-02 taillights conversion
I need help trying to get the ls1 taillights to work on my 1993 camaro z28.
i bought the tailights and wire harness for the lights and hooked everything up and the lights dont work correctly. when i turn on my lights and turn signals they work fine, the only thing thats wrong is when i apply the brakes for the stop lights my turn signal light works as my brake light and still also works as the signals too. could it be a rewire thing???????
Old 04-20-2008, 05:42 PM
Ungrounded Moderator
WhiteBird00's Avatar
To convert from taillights that have the turn signals integrated with the brake lights (like the 93-97 models) to ones with separate turn signals (like the 98-02 models) you have to run separate wires for the turn signals. You can't just use the wires that are already in the back because you'll get the symptoms you described.
Old 04-25-2008, 09:55 PM
JJ93z1SC's Avatar
does anyone have any wiring diagrams or something???????
