Ran a cammed C5Z...
He then signaled for me to exit so we could run with some room. As we were going under the overpass and slowed, I asked him what he had. He told me just a cam and bolt ons. I told him my mods and he chuckled and said he bit off more than he could chew, lol. I informed him it was a fresh motor and that I was running low boost (7-9lbs) as I haven't had it on the dyno yet.
We first went from a dig and I spun through second with him at my rear, hit third started pulling but missed 4th
We next went from a roll with me in third at almost 3k rpms. He honked it off and immediately he got a jump. As the boost kicked in I pulled even, hit 4th and stated pulling. I shut it down at the end of 4th with a few cars up.We pulled over and chatted. He had an HPE 612 lift cam and said he made 440rwhp.. I told him I wasn't sure what I was making but most likely around 550rwhp.. I still have my 3.73 gears and it makes 1st-3rd not much fun as it raps out way too fast. He was a real cool cat with a very sweet ride.
Seems like a pretty masty stang your rockin their. Buddy of mine has a nasty 4v TT GT. But hes going back NA haha.
Can we get a more detailed mod list? Just a lil curious on your setup.
Going na? I use to run be na with a 200 direct port shot. Na is pretty much a waste of time on the modulars.
Basically I just have a 5.0 stroker(sad really), bullit intake, houston performance heads/cams, aeromotive return style fuel system, and a homemade twin 60mm turbo setup. The car also has full suspension. It should make 650-700rwhp once I crank up the boost.
Nice, where was this at?
Gilbert
Sounds like you have a heck of a car there. I work in LaPorte, if you want to give another C5 a try let me know. I dont mind loosing but I just never seem to run across anyone that wants to run.
LionelC
I have been driving it now and then trying to put some miles on the new motor and have had a couple oil changes so I think it is time for a good run. It is still stock cubes, I just had to forge it after a spring broke and the valve beat the **** out of the #8 piston.
LionelC
QUOTE]
Uhmmmm...What? Waste in what sense? Its not as easy as say an ls1 to make power but their VERY capable NA.
His plan is basically a BB 4.6 with 03-04 heads sullivan intake and Some big boy cams. Will lay somewhere over 400 to the wheels. Add in a steep gear and built solid....
Well I dont know about "out gunned". I have the dredded IRS so traction can be tricky. As for a rematch, anytime. I just want to see what she will do.
LionelC
