Street Racing & Kill Stories Basic Technical Questions & Advice
Bolt-on ls1 vs pullied cobra
Old 03-22-2009, 09:40 AM
  #101
registered user
ScreaminRedZ's Avatar
LOL @ stopsign. When's your motor gonna be finished...or is it all just a figment of your imagination, you tease?...
Sarge, I didn't know you were a mod. Cool ****!
OP, good death!
Old 03-22-2009, 10:02 AM
  #102
Tech Apprentice
Stopsign32v's Avatar
Well the feed line going into my passenger side fuel rail is leaking at the 90* bend. I did have Russel fittings but two of the same ones leaked so I went with Aeroquip and I thought it wasn't leaking but then I went to start the car and noticed the bottom of the fitting was wet with fuel so now I'm scared that will turn into a drip. So the next plan is to eliminate the 90* fitting all together. I got this on the way.. http://www.professional-products.com...hose/54181.jpg The leaks on the fuel system are the only thing keeping the car from running.
Old 03-22-2009, 10:15 AM
  #103
Sarge_13's Avatar
Damn man I thought you had that solved? Guess not
Old 03-22-2009, 10:18 AM
  #104
registered user
It's always the smallest bullshit that holds up a good project. The biggest, most complicated projects can go perfectly smoothly until you need to connect two simple pieces of exhaust piping, or keep a fitting from leaking. The joys of the hot rodder, lol.
Old 03-22-2009, 10:23 AM
  #105
Tech Apprentice
Well at first the fuel rails were leaking where the 3/8npt to 6 and 8an fittings were going into the fuel rails. To solve that I put black high temp silicone around where they go into the rails. This worked perfectly. But now I have these leaking on me And there is really nothing that I know of you can do to them to make them stop leaking. So I got that new part coming. But it wont be here til possibly Wed.
