Street Racing & Kill Stories Basic Technical Questions & Advice
lost 2 of 3 to a twin turbo stang
Old 10-27-2009, 10:17 PM
venom ws7's Avatar
Great runs both cars runs hard.
Old 10-27-2009, 10:20 PM
itsslow98's Avatar
nothign a 150 shot wont cure, but holy **** he was coming hard top end. made it look like you let off the throttle. 650hp sure sounds good but it opnly counts if you can put it to the ground, unless its a supra, then its ok if it makes 1500rwhp on a dyno and runs 13s.
Old 10-27-2009, 10:46 PM
silverz28camaro's Avatar
Well the first pass after hitting the limiter on the 2-3 shift I accidently shifted into nuetral. Same as second pass, the tranny wouldn't shift for a second(but didn't hit nuetral this time). And the last pass i let off slightly so I wouldn't hit the limiter, It did shift soomer, but seemed to be stuck in 2nd gear for a second or two.
The tranny and converter needs gone through again. I think if it would have shifted the way it should I would have won everytime.
Plus if you notice the oversized 28 inch tires on the car, they are not mine. My 26'mt et streets are wore out and my boss let me borrow his off his 53 chevy truck that runs 11.8 on spray. I could tell the bigger tires killed my gear ratio, but this guys was saying that there was no way a high 10 sec car cam beat his. Last race spoke for itself.
I did weigh my bosses tires after i took them off today and the front skinnies were only 6lbs lighter per wheel then my fronts(stock snowflaks) and the rear were 8lbs heavier per wheel, so I cam out a little heavier total and taller gear ratio then normal.
I'm hoping replacing my stock midpipe with a 3 inch setup will give me a little more topend
