GTO vs 306 Mustang
I raced a 1995 GT that has a 306 with heads/cam and all the goodies. 3.73 gears, drag radials etc... He made 360whp on a Mustang dyno, my GTO made 385whp also on a Mustang Dyno.
We ran from 45mph to about 120. He stayed with me until I shifted to 3rd, I started to walk out on him. Shifted to 4th at about 100 with a solid 2-3 carlengths, then stopped at 120ish up 4-5 cars.
What's funny is this kid is totally ignorant about GTO's. He thinks that header/tune GTO's cant make more than 350whp and have a curb weight pushing 4000lbs. My car weighed 3770 with me in it (I'm about 170) on the scale at Englishtown. I imagine he's a little lighter, maybe 100-200lbs. That's obviously not enough to negate the 25whp advantage, not to mention power under the curve.
I guess no matter which way you try to spin it near stock 364 is still > h/c/i 306.
Nice kill OP. Was expecting it to be a lot closer, especially with him having the edge in weight and you in HP. He probably has more then 200 pounds on you. For what it's worth, my 2000 GT auto weighed in at 3260. Like you said, he may be lacking some power under the curve. Good kill nonetheless.
Unless its an all out drag car with a built block and a huge donkey dick cam then I don't see more than 420RWHP out of an N/A 306. I agree I've seen more but that was with a completely unstreetable drag car.
My brother has gotten over 500 rwhp out of a 306. He drove it on the street but I damn sure wouldn't consider it a street car. It was nasty and he didn't take it out often but it was tagged and insured. I was just playing devils advocate. A streetable 306 would be lucky to hit 450 and that would be a stretch, more than likely your estimate of 420 would be more realistic.
***Repost Police***
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
What are you guys talking about? No... You will never run into a stock blocked 87-95 n/a streetcar that makes 470rwhp with only 306 cubes. In fact, I defy you to show me one that meets the criteria:
1. stock HO block
2. Any H/C/I package you choose
3. 306 c.i. or less
4. 470 rwhp or more
5. n/a
See, the upper limit of feasibility for n/a power for most gasoline engines is in the 2 crank hp per cubic inch range. Unfortunately, the problem with the 5.0 HO blocks is that you can't rev them enough to get to that upper limit. Anything beyond roughly 7200 rpm and main girdles, and engine braces still can't prevent the main caps from walking.
The 5.0 is my favorite motor in the world, but I still have to call BS on this:
And Manalishi, if your brother made 500 rwhp out of a 306, it was either boosted, nitroused, or had an aftermarket block. So, your reference isn't a good counterpoint for the argument at hand. Once again, I defy anyone to show me a 500+ rwhp 306 SBF using a 5.0 HO block, race oriented or otherwise. It might be possible, but only just... and by a damned good engine builder, and it still wouldn't be something you'd ever run into on the street.
1. stock HO block
3. 306 c.i. or less
4. 470 rwhp or more
5. n/a
It all depends on the H/C/I. They can make anywhere from 290rwhp-475rwhp depending on the combination. Good kill.
Oh, and in a street gas (93 octane), somewhat reasonably cammed 302/306 360 rwhp is phenomenal. That's so good, that unless I looked under the hood and saw nothing but premium parts, I wouldn't believe it either --> guys tend to exaggerate what their cars can do. Mine made "only" about 320 rwhp and walked on a lot of other 302s that made 400+rwhp, or so they said, including a few blown 302s....
A typical H/C/I 302 street car is going to make between 260 and 350 rwhp with very few outliers.
***Repost Police***
Like I said, I was going to the extreme on those numbers. If you make 260rwhp on a H/C/I 5.0 you wasted your time and quite a bit of money. And who said anything about stock H.O. shortblock? We were talking displacement.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Why? There's kids here that do GT40 heads or whatever with the e303 cam and are LUCKY to make 260. Isn't that the cheapest most common setup?
***Repost Police***
If you do GT40 heads/intake and an E303 with full bolt-ons, I am going to assume that you would make atleast as much power as my SOHC 4.6 made. Tons of Mustang guys do full exhaust anyway, so I would assume most that do a h/c/i swap on a 5.0 would too.
The OP mentioned a '95 mustang with H/C/I. I think it's a pretty safe assumption that the mustang in question has a stock block. What percentage of those setups do you think is running a ~$2k block, and would lose to a 380rwhp GTO? I'll go out on a limb and say that it's pretty close to 0%. No one spends 2k on a monster block to make 360rwhp on the street. That could be done using a stock block and stock displacement. I'd also estimate that 95% - probably more - of those that spend the coin on an aftermarket block are not going to stay at stock displacement. The other 5% aren't running their cars on the street - they're at the track in displacement limited classes.
More to the point, when you said it depends on the H/C/I, that alone implies a stock shortblock. Else, you should specify an aftermarket block. In which case it wouldn't "all depend on the h/c/i." It would depend on a hell of a lot more. If you turn a 302/306 to 9000 rpm, then making 500rwhp would not be any problem at all. But turn a stock HO block to 9000 rpm and well... you'd only make it to about 8k before it tore itself apart. I'd love to watch the video of that motor, but I sure as hell wouldn't be there in person.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
