hey i know this is the kills section but i only post here and i know most of you guys and i had a couple ?'s ......first in both an m6 and an a4 what rpm/gear would you be in at 50mph ??......second whats the weight of a f-body ? ,t-tops , coupe , vert ? thanx
Quote:
I have no problem leaving that open. I killed your last post because it was an obvious attempt at creating problems. Originally Posted by 281cipwr
very true ...i was pissed ..but hey its all good ...like southfl said ....ill just sit back and listen ....
!LS1 11 Second Club
With 4.10's 50mph is a threshold for me. Just shy of 50, I'll drop down to 2nd. North of 50, I'll throw it in 3rd.
I think at 65, i'm around 1200-1400, in 6th, just cruising by. I forget really haha. I weighed in at 3460 with a full tank and without my fatty 240lb body in there. It's a fully optioned t-top z.
STF Veteran
50mph? I dunno, I hardly ever drive that speed. I'll pay attention next time I do, and report back.
Btw A4 with stock converter (and 3.23:1 gears) from a 50mph roll will be a DOG. Computer doesn't downshift, it just accelerates in gear. ugh. That's one of the reasons I cruise at 65mph.
You don't want to test my car at a 55mph roll. That's the sweet spot in 2nd gear. All holy hell breaks loose. I'll go to third at anything over 60mph and fourth when over 80mph.
yes i know about the 50mph sweet spot ....i do have a distant cousin of yours under my hood ...its third for me ..damn nice sweet spot
An M-6 with 3.4's will be around 5 grand at 50 mph in second. Talk about all hell breaking loose. A definate sweet spot for those gears. Problem is, many don't want to race from a 50 but from a 60 roll. I need my 4.10's. lol
Quote:
A 60 roll is good for me. Not much gear left when spraying 3.55's in 2nd gear at 60mph on top of a blower making 16psi. Gotta be quick on the trigger. Originally Posted by Dal1as
Quote:
Spraying with all that has got to be crazy. Takes skill. Manuals can be a b1tch. I'll probably run a freaking 13 something the first time I get on the track.Originally Posted by unit213
Quote:
It just takes practice. It's always come naturally to me. It's pretty easy actually. Just tap the clutch about 2 inches in and powershift the **** out of it. It helps having a Pro 5.0 shifter. Still rowing like crazy though.Originally Posted by Dal1as
Takes skill. Manuals can be a b1tch. TECH Enthusiast
I have an A4 vert with stock gears. But with my loudmouth, if I don't let it shift to OD above 50, I start drowning out the Airports from a mile away.
Yeah A4 Ls1's do suck at a 50mph roll, but they do surprisingly well from a 60 or a 65mph roll. Oh and to answer 281's question at 50mph in a A4 you'll be at about 2000-3000rpms in 2nd gear. First gear usually runs out at about 40-45, and 2nd around 80 i believe. I not 100% sure on the 80 because at that speed i usually try to watch the road because a wreck at 80 would be some rough ****. Oh and all of that is with 273 gears which is what most A4 Ls1's come with, other than the occasional one wiht 323's.Originally Posted by Skarecrow
50mph? I dunno, I hardly ever drive that speed. I'll pay attention next time I do, and report back.Btw A4 with stock converter (and 3.23:1 gears) from a 50mph roll will be a DOG. Computer doesn't downshift, it just accelerates in gear. ugh. That's one of the reasons I cruise at 65mph.
Quote:
Yeah, I've always been good with a manual. It's mainly the launching I worry about. (Street tires and am not getting DR's) The 2/3 3/4 I can fly on. I need to get a shift light this spring though.Originally Posted by unit213
It just takes practice. It's always come naturally to me. It's pretty easy actually. Just tap the clutch about 2 inches in and powershift the **** out of it. It helps having a Pro 5.0 shifter. Still rowing like crazy though. TECH Fanatic
with my 3.73s and a locked converter my gears go...1st goes to 44 2nd 77...3rd 126...4th??
I turn 2050 @ 60 mph with my 3.73s
Wes
Wes
STF Veteran
Quote:
Originally Posted by git_sum
Yeah A4 Ls1's do suck at a 50mph roll, but they do surprisingly well from a 60 or a 65mph roll. Oh and to answer 281's question at 50mph in a A4 you'll be at about 2000-3000rpms in 2nd gear. First gear usually runs out at about 40-45, and 2nd around 80 i believe. I not 100% sure on the 80 because at that speed i usually try to watch the road because a wreck at 80 would be some rough ****. Oh and all of that is with 273 gears which is what most A4 Ls1's come with, other than the occasional one wiht 323's. I thought most A4s came with 3.23s? Maybe I was lucky to get them on mine. I didn't even know to check the door codes to find out till I'd already owned the car for a few days.
Agreed on 65mph. The only stronger speed I've found to launch from in my car is 25mph (well, and maybe 0mph. haha). Stomping on it at 25mph, I have **** fly out of my pockets (cell phone jumps out almost every time), and one time I had a dry leaf that'd made it's way all the way at the front of the dash, fly backwards from a 25mph WOT burst... and the windows were closed.
With my factory 3.42 gears in 6th gear at 50 mph I am at about 1000 rpm's exactly.
id be in 2nd gear if i were goin from a 50 roll, somewhere in the neighborhood of 4800 or 5k rpms, if i drive my car ill see tmrw
