Detoxx vs Supra
Helluva job your car did keeping up as well as it did! What's up with the Supra jumping early EVERY TIME? Guys got alot more power and still feels the need to cheat? For the record, you are supposed to leave on the third honk, not inbetween the 2nd and 3rd honk...
Percentage wise, there are as many built Supra's that are good at digs as there are fully built Mustangs that aren't good at a dig. Just sayin...
You should fair pretty well from a dig since your car is probably making close to, or just over 600rwtq and he is probably only making high 400's to low 500's and his car should be a couple hundred pounds more than yours.
And you don't need a F1 to smoke him. A D1 will do just fine
You will probably run into even distribution problems when you get too far above 200 shot with just a single nozzle kit. I wouldn't advise any higher than a 225 without a nice dual nozzle setup or direct port kit. Run a cylinder lean and you will melt a plug.
#36
#37
F1 will make more overall power, but on a 347, a D1 will be more efficient. Check Kp's threads. He has had several procharged cars. F1 was barely faster than the D1 car in the eighth and quarter mile.
