How fast is a 2005 ish 911 Turbo? - Dead even
More timing is needed for less efficient engines. Less efficient mostly has to do with quench and combustion chamber swirl: areas where the lsx heads are hands and feet above the classic hotrod heads that usually needed 32-38 degrees total timing to run there best. Hell, even back then the total timing number that made the most power (assuming no pinging) was universally considered a barometer of the quality of the heads.
Man that's alot of timing for a ls engine. You don't want to be past 28 degrees tops: and with your setup you would/will find that 24-25 total degrees timing is all that you need. Been awhile since I saw a timing curve for a ls engine, but I do believe that the timing is all in by 3000rpms? Check around.
