My evo showing what up VIDEO*
#41
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#43
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#44
I know that the 37r is outdated now, but I baught the 1st 37r kit ams came out with back in 2006. Im on a .63 5 bolt hot side (which as far as i know cannot be swapped for an .82 hot side), so the price to upgrade just the turbo and the limited power gains is not worth if for me $ wise. Right now im contimplating on switching to a different turbo kit with an .82 hotside, but i have to get my trans issues dealt with 1st. Plus im at that point were i dont really feel like dumping more $ into the evo.
#45
Will, I make 55 gallon drums for a living so if you need one, just holler. Oh and I'm down for a bdubs meet. Although I won't have my **** done til next spring, I'll bring the G.
#46
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
BTW, spoke to Larry, it's going to be at least 2 weeks with the things I'm going to have done. Made some bozo no-no's with my build so they are going to tweak a couple things
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
No ****, small world. Soooo, can you fasten some sort of pump to those things or do you just use an external cyphon?
#48
They are relocating my coils so the wires are safely out of the way, changing out some pcv line for higher temp stuff, extending the wastegate pipe, little odds and ends. Overall Larry did say the build was pretty good though. Just a couple of things to make it better.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#50
No worries, I'll have a low boost setting for you to work with. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
BTW, spoke to Larry, it's going to be at least 2 weeks with the things I'm going to have done. Made some bozo no-no's with my build so they are going to tweak a couple things![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I'm not sure what it's called but I will take a picture of it tomorrow and show it to you. But what it is, is a manual hand pump and all you do is turn the handle and it pumps whatever you have in there out. It's hard to explain but you get the picture I hope lol. Keep me posted if you need one and I can get you 'em for cheap.
