Mach 1 vs Turbo Tc
#82
Because 03 mach is leaving out the hole with like 290 hp or what ever mach1s have stock at the rear wheels then it spools up after the inital hook. Where hios makes alot more instant all motor power.03 mach can go wot imidiatly
#85
Lol not exactly but close. The mach comes up on boost very fast but it doesnt shock the tires like the all motor car. All this happens very fast but you can see it outside the car when watching closely
#86
You should know a prepped track will hook better than the street. Hell I usually can't even go wot in 1st on the street. I'm working on that....we'll see. I'm in the middle of changes that I can't get the time to finish.
#88
Not something I ever worked on much. 10bolt is the limiting factor when leaving on it anyway. Busted a axle last time at the track 2-3 weeks ago. Besides, it's not a drag car really. It's a car I drag race from time to time. When the 18's are on it it can pull over 1.1 g....that's when it's a fun car.
#90
soo hio im not scared to run my car, I'll run you anytime anywhere, I'm not not scared win or lose it all in fun.
#91
cool, run it nov 5th. Super stock cars will be there so the track prep will be good and it's a test and tune. You should go faster than ever. That time just mentioned is the best your car has done that we have ever seen. If I remember correctly you had almost all your interior out and was really goin for it that day and **** talked like mad. I set a new best. So not a bad day.
#92
#94
Already have, You said it only went 119, wrong... everything you think you know has been wrong..... You haven't been there everytime I've ran it and i'll give you JW's # so he can tell you what it ran. I can't find the time slip but I'm sure there in berryville if you or nathan wanna go pick them up. I have nothin to prove to you. I already proved you wrong
#95
My car went 11.4 @ 122.xx that day on shitty 1.85+ 60's and set a new best. If you ran what you said you should have out ran me when we ran....well you have'nt. You don't have to give me JW's number, I have it.
If this is the case that you have been faster....then you done a good job slowing your car down.
#96
#97
#98
#100
lmfao, I had that one comin, Next Question reguarding jw: Are You the owner of his first cousins girlfriends first born? roflmao Its like this 11.50 i wanna see proof your not the owner of it!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
