Street supra vs. Turbo GN
Actually in 1987 there was no ttype-it was called t and the GN motor/trans combo could be had in any Regal trim(even chromed out custom limited models). I have seen column shifted 87 Regals with the turbo motor combo. The dead giveaway is the hood to spot the real thing if it came from the factory as a turbo car..
There were even black turbo regals that WERE NOT Grand Nationals.
87 had a tad more power due to the tune-both the 86-87s cars were underated.
With almost 50% more power at the wheel, and at probably the same weight, that Z06 is going to get pulled on like that either way.
Stock means stock. Not stock with modifications, because then it's not stock. "Yeah it's stock with a big turbo, a donkey-dick cam, Jesus strapped to the engine block, and a damn jet engine. But other than that it's stock!"
no replacement for displacement is 99.9% true. the 1% is the turbo
3.8L L36. didnt the turbo trans am use the same setup also? those engines seem to make LOTS of tq for there size.
that right there!. its misleading lke the supra is actually hanging but thats not the case. the GN is spinning his tires and fish tailing. then it hook and Bam he leaves the supra.
#32
That Supra hits really hard from the jump. No Bzzzzzzzzz.......pssssssSSSSSHHHHHHH jive going on there. It just pulls instantly.
I'm not even going to mention the Buick because it's just a nasty rapist.
