Ported blower cobra vs h/c ls2 vette & more
#41
#44
#46
Slighty same set up. I'm finishing up the car tommorow...
Only have to put the water pump back in and radiator.. Started raining hard down here and had to stop but if everything goes good I'll have rpm tune it Friday and head to Ohio later that day.. My winter tires are
contential d/w's.. I'm not going to put the shitto's on and drive 580miles one way with 40% thread remaining.. There's simply not enough room in the trunk to throw them in. I just got done replacing damn near every gasket.. So there shouldn't be an issue this time.. • knocks on wood•
#48
After I swapped the timing set and the new oil pump the car felt like a different animal... Wasn't throwing any codes or anything.. Just the oil pan gasket went out.. I'm not going to high jack limit thread so if your curious about that you can check my build thread. If I'm right the only things I'll have on limiter will be und pulley, heads milled, thinner head gaskets, k&n cai, ported tb and ported intake, 3.90 gears, and short shifter..
#55
#57
I'm excited! Hopefully you can be my
First race with the car running 100% when I raced that c6z I had these same
Tires from a 35ish roll but I was in 2nd gear and the car was fairly hesitant, throwing codes and was just dumb on my part.. I know there's some nice roads in that area where you can stretch your legs a bit... I also bought one of those expensive radar guns for trips to mexico
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#58
Damn nice. I will be up that way in a month. Getting married in Groveport. I will be staying in Pickerington. I never see any cars when I am there. No one has window tint either. Haha
#59
Tires from a 35ish roll but I was in 2nd gear and the car was fairly hesitant, throwing codes and was just dumb on my part.. I know there's some nice roads in that area where you can stretch your legs a bit... I also bought one of those expensive radar guns for trips to mexico![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#60
I kno those areas! I used to go to eastland career center. It's next to grove port high school.
