ls1 vs lt1
#43
http://www.amazonsupply.com/odyssey-..._pf_B0002ILK7M
#48
https://ls1tech.com/forums/sponsor-s...e-battery.html
Read through the thread and he claims its perfectly fine for a daily. Was looking into the miata battery but how much does it weigh?
#49
I've been through this batt. ****. it really don't take much to start the car. When it really loads the battery is setting in traffic with the blower goin, wipers wipein, headlights lightin and the radio goin. The really small batteries just don't have the capacity for it. That 680 will reset your trip meter to start the car. You think, huh......not a big deal. When it does that it also resets your fuel trims.
#51
Found this aswell, they are local to me i just sent him a PM.
#52
Here are some that LOOK good but I can't get any data or feeback on a street car that is daily driven before I spend the money...
lithium pros C680-super light but expensive. I don't care as long as it works
Deka Big Crank ETX18L-you will need the Odyssey SAE terminals ODY-3217-0006 to make it work. BatteryMart.com sells those
#53
FYI.... Battery Mart .com is in Winchester.
#54
Guys take a look at this one
http://www.performancedistributors.com/batteries.htm
Thats pretty awesome ill look into that. Thanks man.
#55
The oe battery weighs 36lb.
I've emailed with lithium pro's before. He seemed to think it would do the job and has some running around on ls cars and says they're doin fine. He will cut ya a small deal on the 680 to $475. But you would probably be better off with the bigger one (925).
Wow hmm I might buy one from them when I am up there
hmmm, i wish something in the 10lb
range was good enough for a daily thatd be badass.
wow what a turd.
wow what a turd.
I wonder how that one is that you quoted...
#56
#59
what sucked is the ta drug all of our ****...bad...regardless of weight haha.
#60
this. the ta weighed 3580 "cleaned out" with nothing in the car except what it came from the factory with and a full tank of gas. they are certainly tanks. my all option 2000 a4 camaro *only weighed 3480. my friend's 2000 a4 b4c weighed 3380.
