Street Racing & Kill Stories Basic Technical Questions & Advice
ZYBORG vs GTR vs GTR vs SUPRA
Old 06-27-2012, 01:43 AM
  #61
ohioborn80's Avatar
Originally Posted by Redfire 03
I'm still waiting to see a respectable *ET* for the mods from your car. Wonder when that's going to happen.
Respectable ET? 4 mods and went 10.60@130 is doing pretty good. Figuring that was stock suspesnion, stock headers, stock tranny minus stall, full weight of about 3900lbs with me in it at 2600 DA. Slap a $3500 sc, off road x pipe,intake and go mid 10's with less then 500 miles on the car. Yep pretty good. I am waiting on you to get something that will out run me. Till then you have no room to say **** but I am faster.
Old 06-27-2012, 01:44 AM
  #62
ohioborn80's Avatar
I've personally seen that Camaro go 15X traps spinning. You're sure going to need a lot more than you've got now.
AND? I guess no one else can mod to that point he is at? I just added 100whp in less then a month. Still stock engine. Now have to make it hook. Already trapped 3 mph higher then best of 131 with it spinning with a sorry 1.8 60ft.
Old 06-27-2012, 07:41 AM
  #63
HioSSilver's Avatar
Originally Posted by ohioborn80
If he only made 405whp with full bolt ons he better get a new tune or something is wrong with his car. He should make least 430whp on a bad dyno. I know me and my buddies full bolt on manuals both made 450whp+ on the same dyno. Both custom tunes only diff was he had shorty headers I had long tubes. I ended up putting down 464 with some more tweaking to t he car. It ran best of 11.4@119 in 87* weather.
Your bolt-on car was a bit of a dyno queen. 464whp and 6k+ clutch dumps should do way better than 11.4 @ 119
Old 06-27-2012, 07:55 AM
  #64
Killemall's Avatar
To the boss guy...
A stock z06 will demolish you. Im talking ugly.
When my viper was stockish with just an air intake at 457 rwhp and 490 rwt at 3390 pounds I raced a stock 455 rwhp z06 probally 50 times or more.
Sure from a dead stop to 125 mph I could beat it everytime simply because I was the better driver by far.
But from literally any roll speed to 140 mph that stock z06 would put two legnths on me every single time.
Basically you have no idea what your focken with.
Recently I was a passenger in a 570 hp lp570 superlegerra gallardo. 130 mph and 11.1 with 0-60 in 3.1 bone stock.
Another buddies stock z06 challanged us and ill be damned if the z06 wasnt only a car back at 120 mph. Z06 was solo while two of us in the lambo but nevertheless gotdamn!
Old 06-27-2012, 08:46 AM
  #65
AWDTBSS's Avatar
he was right at 570whp with the 150 shot. Mild cam and bolt on. I was making a little more then 620whp when raced him as i had just put the aluminum driveshaft on and off road x pipe maybe a little closer to 640. He mentioned his bottle pressure was only at 850 so that could have been his issue.
with one you one mentioned that is good. I also haved trapped as high as 132mph while going 10.6's and launched only at 1800rpms and not off the convertor. I needed better tires then to launh off it. Now with new power making 713whp I can't even launch off idle with out it getting sideways. The MT DR's are almost wore out and I am going to try a Hoosier DR as some buddies making as much and more power as me have great results with them.
you sure it wasnt just bolt ons and spray? Cuz if it made 570 on the 150 shot that'd mean its around 420whp with Cam/Bolt ons which is terrible lol those are normal bolt on numbers
Old 06-27-2012, 09:16 AM
  #66
ohioborn80's Avatar
Says the Guy with a swapped engine who gets to run in great da...11.4@119 in roughly 2600 da is pretty good. Specially still weighing 3650lbs with driver.
Old 06-27-2012, 09:20 AM
  #67
ohioborn80's Avatar
Nope it has a cam and bolt ons with the spray. And that is what he said makes for power. Not sure how his shot is rated either. Wheel or crank HP. I will get a video of it and get it on video if we run again. He just took to drag strip for first time. Heavy chrome 20" rims and all. His best was 12.4@127 with a shitty 2.3 60ft. Street tires as well.
Old 06-27-2012, 09:32 AM
  #68
evangto87's Avatar
theres nothing wrong with his tune. His car mphs right around 119mph. So im doubting there is a 60whp different between yours and his.
Old 06-27-2012, 09:38 AM
  #69
ohioborn80's Avatar
405 is lowest for a full bolt on 5.0..and what kind of da he run in? Temp etc. My manual trapped as good as 122 for me just not at 11.5 but 11.5. Which even then there is a bunch of full bolt ons that run closer to you at tracks up north that run lower 11's or 10's and all trap 120-125. They don't have to worry about running in 100* weather.also I think the 4.10's hurt my manual. Had me going threw traps in 5th gear at only 6000 rpms.
Old 06-27-2012, 10:08 AM
  #70
evangto87's Avatar
464whp just sounds high. The highest ive seen from any bolt on 5.0 anywhere with the acception of your dyno, is low 430s. Dynos vary. There are also ls2 stick cars out there that make 460whp + with cam, full exhaust, fast intake. My buddies only made 422whp. There have also been stock bosses that dynoed 415whp... there have been some that dyno 385whp..do you really think theres a 30whp swing in stock cars? All dyno variance
Old 06-27-2012, 10:11 AM
  #71
ohioborn80's Avatar
Agree dynos vary. And I have seen plenty full bolt ons make 430-460whp. As said a lot depends on dyno. Also tune. Most are doing email tunes. Not dyno tunes maxing everything out. My tune was very extreme. 26* timing a/f of 12.8-12.9.
Old 06-27-2012, 11:03 AM
  #72
AWDTBSS's Avatar
Oh well his numbers are really weak either way. Bolt on only LS3 can make 420-430whp so only making 570whp with a 150 shot camd/bolt on is extremely low I mean unless the dyno he used is a very low reading dyno
Old 06-27-2012, 11:15 AM
  #73
marc97taws6's Avatar
How did you get the supercharger for such a good deal? I thought they are at least $4,500 for the base kit
Old 06-27-2012, 11:45 AM
  #74
Mike Morris's Avatar
OMG the egos and hurt egos in this thread are crazy......
Zyborg ever run your Z at the track?
Old 06-27-2012, 11:48 AM
  #75
HioSSilver's Avatar
Yep...the difference between me and you is my **** is'nt under performing. .....You walked right into that. That da your talking about would be worth .2 at most from perfect. The tracks I run at don't see perfect that often. When I went 11.1@126 the da was in the 700 range. That only leaving 1900 for you to whine about and still don't explain why you went 7mph slower with 40hp more....well not really you but the shop runnin your car.
Old 06-27-2012, 12:56 PM
  #76
evangto87's Avatar
all i said was i think me and zyborg would be a decent race. Both our cars seem to run a bit stronger then the average mod for mod and we can both drive them. As far as c6 z06s... i dont mind losing to them considering they out run most 250k cars as well.. so its all good in love and war . Ill just suck one up when i have my 10psi and extra 250hp
Old 06-27-2012, 01:14 PM
  #77
karpetcm's Avatar
Zyborg's car will eat you up and chew you out, its a machine from the planet called Zygon which explains the abnormal speeds its capable off.
Old 06-27-2012, 01:23 PM
  #78
evangto87's Avatar
i dont even know how to respond to this.... cool?
Old 06-27-2012, 01:29 PM
  #79
karpetcm's Avatar
lol its not meant towards you, its a response to all the vidz i see of him pulling on some insane cars. Now in response to your post you made earlier going up against Zyborg that will probably be a good race.
Old 06-27-2012, 01:52 PM
  #80
evangto87's Avatar
Its always tough to say online. I dont think he has anything hidden. I figure he makes about 390whp and with a light car and some good driving that can beat a lot of things out there. I saw a vid on here of a full bolt on 5.0 racing a full bolt on c5z. Both guys rowed the gears fairly well. GT made 407, z06 made 390. They were side by side with a slight edge to the z06. The problem with the new 5.0s is that so many people can afford them and give how strong they are a bad name. There transmission really does help out the power to weight ratio advantage of the vettes. But either way... i want to run a bolt on c5 z badly.
Quick Reply: ZYBORG vs GTR vs GTR vs SUPRA
