Sweet_SS at the track
Well I finally got the car out before the end of the season. To be honest, I'am happy with the run, especially for my first time racing this car at the track. I was on some ET Streets and foot braking making around 3psi at the line. I tried to rev the car, but ended up pushing through the brakes...reason for the red light. Also, it was pretty damn cold and I didn't drop the tire pressure all that much. Ended up with a 2.2 60 ft. The car is on 9psi w/ stock 10 bolt. Adding another fuel pump and taking the boost up next year. But for now here you go.
If you can get it to launch, you ought to be able to get into the 11's with that car. I'd work on the launch first. More boost won't really help if you can't get the power to the ground.
The tires actually hooked well. I couldn't build that much boost at the line. Kept pushing through the brakes. I didn't get any wheel spin either. But I do need to get it out of the hole. If I could have gotten a decent 60ft...1.5 or so. I know the car would have been in the low 11's. So the power is there.
10 bolt is fine with a auto. I went 1.6 on one with 373 gears in it for 2 years. also. wtf. 9 lbs and trapped 116? who tuned it? a head cam 376 minus boost should be trapping more than that I would think.
nice car though.
nice car though.
Well I am racing with altitude...4400ft above sea level. The company who built the motor also tuned it. They are well known and very reputable. We actually compared my setup to a 5th GEN Camaro with a Procharger....tuned by another shop on the same boost. He was on street tires, but ran 13.3-13.5 @ 112. The shop that tuned mine, just made over 900rwhp out of a procharged ZO6 on 10psi with belt slip. Plus there are a handful of 1000hp cars they tuned as well. I have to run more boost to make power unlike some of the guys here that are at sea level on the same boost as me. It blows, but what can you do. Hell H/C guys here are only making around 400hp and trapping below 110. But thanks for props on the car. Have a ton to still do.
