Bolt on Mach 1 vs bolt on LS1 from a roll
#63
Watched the video again. Looks like that Camaro started half a car back during the honks, missed the hit, and was clearly at a bad speed for the gear.
Why didn't you guys do another run?
#64
agreed! or invest in some good drag radials! my h/c stock suspension vette hooks from any first gear roll unless its like 17 degrees out and then just heat them up and they stick. It hooks from a first gear roll on spray as well.
#67
He started in 2nd for sure. You already had momentum from the hit. It was his dumbness. But to think you would still beat him after he does bolt-ons is your dumbness......but this guy is pretty dumb so he might end up with a 13 sec full bolt-on ls1.
I might be ignorant....but I know how to get these ls cars to go.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
fwiw - I did mult races with a geared mach 1 when I had bolt ons. did 40s in first and in second and the outcome was the same every time. so from my experience, with 342s it dosen't matter if its 1st or second gear. and I had drs too, so it would hook in first.
thats all he is about man, excuses...
#68
#74
#76
#77
