Race Gone wong!! Turbo NSX vs Nitrous GT-500
#42
the issue with the gt500s was and still is... weight balance. For example. My car is 46/54 front from the factory. The 2013 gt500 is the same car now adding 300lbs to the nose. And thats with an aluminium block. Now add the weight of an iron block to it....
Last week at my buddies speed shop, there was a 770whp gt500 on the lift (built motor, tvs2300, pump gas). Basically to make the car hook, he wanted to raise the back a half inch... and add 200lbs of lead plates in the trunk. Then he could properly set the suspension. Bottom line is there is just no weight over the already too narrow tires.
Yes!!! Lets make another thread about how awesome you and your boss are!!
#46
Dude you are such a ******* clown... **** off! I was explaining why they are notorious for spinning tire... what that has to do with me or my Boss i have no idea. I referanced my car to show that it was already nose heavy and how the GT500s pack there extra 300lbs right over the front tires. Just another mindless troll on ls1tech.
#47
#48
#51
Ok so advice from u nitrous guys.. I'm gonna be running a 100 shot thru my Maggied forged ls6. Standalone with race gas and a NOS 90mm plate system with a NOS window switch. What would be the max rpm to WOT with out backfire. Just so it's in te back of my mind when ****** around
1)Bottle open-either I twisted it, or you go remote.
2)Arming switch,...to energize the system...and everything is a go.
3)WOT switch wherever and however your get the signal, mine was at WOT @ pedal and firewall
4)Fuel pressure safety switch(i didn't have)-smart though-you drop fuel pressure , usually rail, it disarms nitrous.
5)"window switch" turn turn nitrous on @ a pre desired user chosen RPM...like, 2800rpm...for example, ...so if all above are in line, @ wot, and 2800rpm,..your nitrous would engage.
5a)"window switch" cont-you need an rpm to SHUT OFF..so,..if you redline @6800...then maybe 6700, or 6600rpm would be a good time to get comfortable to have it shut off, incase you over rev on a shift.
I only mention all above, cause some of us, just haven't tried nitrous, or are unfamiliar with it, how it works, and how to use it safely. There are a few more variables that matter but, the above, is the basics. Just like there is elaborate boost controllers, there is elaborate nitrous controllers. Time based, you could make a nitrous car hard to beat if you had your **** together. Problem is, nitrous, the way I wanna use it,...is brutal on parts.
To equal what I made from adding 11psi of boost, I picked up 333rwhp. Useable. Nitrous,.useable only @ wot, on a 330 wheel shot, would be decently violent. Like, ****, that hurts, violent.
Anyways, I think until you have your comfort/shift zone figured out, i'd end your nitrous blast 200 rpm sooner then rpm redline,...to prevent any kinda of bouncing off rev limiter. If your shifting is sluggish(we all gotta start somewhere)...shut if off 500rpm sooner. Theres no shame in saving your motor. In most cases, most cars stop pulling in the upper rpms anyways unless you got a fluid setup.
Sorry for the rant-I am by no means a nitrous guru,..just experienced it on my own, and several setups,and types.
Typically happens with WET systems, a nitrous system that sprays FUEL and NITROUS....as opposed to a DRY system, spraying on NITROUS.
Also, usually on systems that have nozzles BEFORE THE THROTTLE body are potentially more prone to having an issue ....but it is caused by FUEL PUDDLING IN THE INTAKE MANIFOLD, so direct port or single fogger, Usually, fuel puddling will occur in the back of a manifold,.... that **** ignites.... boom. Several things could cause this to happen. Bad designed system, stuck solenoid, driver error-etc...
My issue was my fault, I went WOT at to high of an RPM speed....once I went WOT,..the spray came on INSTANTLY,..the car blew the tires off...RPM's SHOT through the moon......I lifted but had already bounced off the rev limiter once,....suddenly,...flames shout out of every seam of my hood(it was at night)....if you blinked, you missed everything,..I didn't blink, my hood bowed open like a balloon, then closed again...the car had a massive vacuum leak since I blew the manifold in pieces. Fortunately, the fire was out as I came to a stop.
I cleared the multiple codes with my DiabloSport Predator,...started the car,..idles @ 3000rpm..lol...and I was able to drive it back home. So, don't hit the spray when your to high up in your rpm,...just pick your race better or slow down...etc.
Nitrous can be safe,..and really easy to use, just gotta be smart when your installing, pay attention to your wiring, it is absolutely crucial if you really love your car. You don't want to catch the car on fire for doing a halfass job.
Anywho,...not a nitrous guru...just my experience. Currently we run a few cars on nitrous, a direct port 500+ capable car one or two more, maybe.
It's fun,...just brutal on parts, and wot dependent(safely).
#52
#57
From what I've seen and read, nitrous backfires come from the air velocity being to low and can't carry the nitrous through the manifold. It puddles and ignites. B-Series sounds right on the money. I'm almost finished with my setup, and have a SafeCraft fire suppression system, just in case.
#58
Also its the fuel that can puddle up in the intake, not the nitrous. That can cause a back fire. Its the most COMMON way, but not the only way. Guy i used to know had the worst luck with faulty NOS solenoids. Multiple fuel noids failed and kept leaking fuel into the intake... cant tell you how many times he turned his car on and blew his intake tube off.
#59
Very nice setup.
#60
The older NOS fuel noids have issues with leaking due to constant pressure behind them. This was a solid 5-6 years ago. It wasnt a large enough leak to effect a/fs. It would only be pressure bleeding off and puddling into the intake through the noid. This only happened during start up.
