my best Friend mustang 5.0 2012 vs the world
Although I do wish I could apply my 14 dogs for welfare down here as I have them applied in the U....You see hear anything.
Not a fan of the 5th gen camaros so heavy for what they are and most people don't even really use the IRS to its potential might as well have a live axle in the back. Put a ls3 in a 4th gen watch it rip.
I've been told that you can go as high as 18 psi on a stock Eaton, but from what I remember it creates A LOT of heat and the power drops off earlier in the rpms (around 5000). I'm not sure if porting the Eaton has any effect on how much more boost you can run, but it does increase the useable rpms. From what I've been told, anything over 16 psi is counter productive, great torque but the peak power suffers because everything is shifted lower.
Most of my friends run around 14 psi on stock Eatons.
I'm not a Eaton expert, just going off what I have been told in the past.
#36
#38
i got a video on here somewhere where i raced one, and its put down some fast cars at the track. but from a 30 roll and he jumped me bad both times i was still about 2 cars behind . and i had my nitrous plugs in the car. he did pull me in the mid range tho but it was alot closer then i thought it would be.
