toxic c6 vs built g8 gt
Calling out all street cars huh? I got 3 cars that you can't **** with. Period. One of them you already ignored the call out on ms/tn/callout spot. The other one half tracked your *** at Lena. You aren't ready for the junkyard dog.
So lets see:
The toxic c6 has backed down from a cam only full weight fbody.
Got half track drug by a stock bottom end c5
Can't mess with a sbe heads/cam/intake fbody.
-Jacob
So lets see:
-Jacob
Only been to lena twice and never raced a c5 once.
His cam only nitrous car. He wants to run me in.
What's wrong with the tune in the car? If you're talking about it dying, that's because when I rolled out the tires grabbed hard and it bogged the motor down. That's the only time it's ever happened. It actually idles at 750 and has a large cam.
I'm not much faster than u on motor. I offered u as many lengths you think u need on motor. Where u only offer me 1 length and the hit with u on spray and u run 9's. come on man really. I was trying to be fair.
#36
Best pass of 11.48@118 on motor vs 10.xx@130. Yeah that's real close.
The car is 3500lbs with me in it. Only weight reduction are wheels and rear brakes. Still has completely stock front suspension.
It actually ran 9.9x@136 on a 175 shot. Ls6 intake, unported throttle body, stock pulley.
#37
#39
From LS1tech(outside this section, there is a forum, you know?);
Since the LS-engine series has evolved, I decided to take the "Fastest Cam Only LS1/LS6" list and update it to include LS2, LS3, etc. All times must be on stock heads, crank, rods and pistons. Post up your times and I'll bump and add as I can. Keep in mind it may take a little bit longer to update the list at certain times, but I have a life outside the board too (amazing right?)
LS1 / LS6 engines
Board ID - 1/4 ET @ MPH (60ft), Year & Type of car, Engine Type, Transmission, Converter or Clutch, Gear Ratio, Cam (with specs if not a widely known one), DA, Race Weight, Date
F-body
1. SSPerformance 9.986 @ 132.27 (1.31), 94 Z/28, LS1, TH350, ATI, 4.33, TRex, -270, 2900 lbs, 11/10
2. Smokin01ta 10.219 @ 132.29 (1.38), 01 T/A, LS1, M6, Spec4, 4.56, TRex, -1100, 3010 lbs, 3/06
3. LS1Joe 10.232@132.04 (1.39), 02 Z/28, LS1, M6, Spec4, 4.71, 250, -1100, 3150, 03/06
4. Josh@KY-Turbo 10.291 @ 128.07 (1.33), Z/28, LS1, TH400, 5100, 4.11, 239/247, 878, 2953, 9/11
5. 01-Z 10.295 @ 128.48 (1.38), 01 Z/28, LS1, TH400, 5500, 4.57, G5X4, -110, 2880, 4/05
6. Magnus 10.295 @ 128.48 (1.36), 97 Firebird, LS1, TH350, 5500, 4.10, G5X4, 200, 2820, 4/05
7. Dragaholic 10.340 @ 127.46 (1.36), 00 SS, LS1, TH350, 5500, 4.56, TRex, -700, 2850, 11/05
8. Minshall 10.384 @ 127.53 (1.37), 02 Z/28, LS1, TH400, 5000, 4.10, G5X4, +1897, 3125, 10/10
9. SSmokedLS1 10.48 @ 130.29 (1.45), 01 T/A, LS1, M6, Spec4, 4.56, TRex, 800, 3035, 3/07
10. Johnathon @ Tick 10.509 @ 131.99 (1.478), 99 T/A, LS1, M6, McLeod Slipper, 5.00, The Polluter, 48, 3020, 11/09
11. Trevor @ TSP 10.510 @ 125.80 (1.43), 98 Z/28, LS1, 4L60E, 4500, 4.56, MS3, -1000, 3175, 2/05
12. fatboyzcamaro 10.550 @ 125.38 (1.390), 00 Z/28, LS1, TH400, FTI 5200, g5x2, 3.70, unknown, 3120, 11/11
13. Project_SS 10.561 @ 126.74 (1.44), 98 SS, LS1, 4L60E, 4400, 3.73, Vind, 2400, 2840, 7/07
14. Chrs1313 10.617 @ 124.66 (1.356), 02 Z/28, LS1, SS4000, 230/230, 4.10, -870, 3250, 10/09
15. studderin 10.660 @ 129.89 (1.482), 01 Z/28, M6, Ram HD, 4.30, street sweeper, unknown, 3160, 11/11
16. DMcRacer 10.738 @ 125.06 (1.46), 02 SS, LS1, 4L60E, 4600, 3.42, AMS, -1080, 3375, 1/05
17. Jason99ta 10.783 @ 128.27 (1.56), 99 T/A, LS1, M6, RAM, 4.56, TRex, 1300, 3253, 06/04
18. CanuckSS 10.793 @ 128.96 (1.59), 98 SS, LS1, M6, Spec Stage 5, 4.56, TRex, 580, 3000, 10/10
19. GrannySShifting 10.821 @ 126.9 (1.47), 97 SS, LS1, M6, Tex, 4.56, PSI 233/238, -1000+, 3458, 11/08
20. Demonicbird00 10.846 @ 127.80 (1.571), 00 T/A, LS1, M6, SPEC Twin, 4.10, KOD 245/250, -1181, 3190, 11/10
21. PewterZ28 10.857 @ 123.53 (1.46), 02 Z/28, LS1, TH350, 4900, 4.10, G5X4, 46, 3310, 10/06
22. BAIN 10.871 @ 122.24 (1.49), 00 SS, LS1, 4L60E, PTC 5100, 4.10, TR T-Rex, -157, 3260, 10/09
https://ls1tech.com/forums/drag-raci...s-engines.html
