'12 3.7l v6 vs. H/C 347ci Fox
Lolz WRONG
I'd like to find a V6 with a couple of mods to run..I think it would be door to door. They do run good from what I have seen. Amazing what can be done with NA 6 cylinder motors today.
Dude read it... It says "all stock except to clarify that the following items are the only things not stock on the car. Its alot more clear than what alot of people put, "heads/cam/intake" well... that leaves alot to the imagination. Hell I'm still on the stock tune... It just runs good for what little has been done to it. Not sure why that makes you butt hurt?
If that's the case, every car is stock, except for xxxx mods. So my GTO is stock except for the different tires, different heads, different valve springs, different valves, different radiator, different supercharger, different pulley, different air filter, different headers, different mid, different catback, different weight, different things removed, different window sticker, different shifter, different clutch, different fuel pump, different fuel regulator, different injectors, blah blah blah. But it's all stock, other than that.
Just pointing out that it's funny. Sorry if pointing that out hurts your feelings.
They do not run door to door with machs. The v6 cars are slower then a stock 3v and a mach is faster then a 3v When they get boltons the gap gets even bigger.
#37
