cam only 5th gen vs full bolt on 5.0 coyote!
Don't get me wrong coyotes are beast with the "RIGHT" setup as well as some bolt-on 5th gens. Mine is setup for the streets but run mid 7s in the 1/8 mid high 11s in the 1/4 on the stock cam. My buddy's bolt-on 5th gen runs 11.40s and 7.20s in the 1/8th and some cammed 5th gens can't touch his times lol
Your doing better then most. But I know several bolt on 5.0'ds that ruin 10.8-11.2. My own 5.0 manual ran 11.4's with bolt ons. went 11.8 with just tune and tire. I see a lot of 5th gens struggle to get out of the 12's with bolt ons. And even struggle to hit mid 11's with a cam.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
And you were 1.5 seconds back......what was wrong with yours??????????? They all run 9's. Do you suck that much??????? Are you to stupid to point it down the qtr and push the gas?????? I mean come on Ohio.....something had to be wrong with yours then.
Maybe cause I was 3650lbs, on DOT tires not slicks and still drove my car every day. Wasn't a full suspension, still stock seats, radio, ac/heat etc. .
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Acually the trans is not super built.....It has all the stock pieces except no sycro's 1-4. The car chassis has not been cut anywhere......more miss info.
Yep.....it's got a rear now
Your dumbass proved you couldn't drive a stick
Your dumbass has also proved that all the bullshit you talked you couldn't do.
#35
bolt on 5.0s do good but they all dont run like that . i was 7-0 vs bolt-on 5.0 and each and everyone i ran from a dig or any roll they thought they had the advantage.(they picked) my camaro was nothing special full exhaust , intake , tune, cam and spray but not used in these races. i would pull them by a good amount and most would get me off the line and i would pull around them. best my car did was 11.6. but i never launched it. always mid 1.8 60' as i was stock driveline . but no doubt they run good. but i seen alot of 5.0 in the 12 and very hi 11's with boltons. the 5.0 does alot better at the track for its 60' u get a 5th gen to 60' they are close. but thats part of it. i did have some weight reduction for the track but when on the street . it was close to full weight.
#36
