cam only 5th gen vs full bolt on 5.0 coyote!
#61
***Repost Police***
#62
I'll shoot him a text to check. I can't remember. When he was doing it I was trying to get him to go off road mid, but he wanted cats for emissionsand he ddidn'twant the gas ssmell with no cats. So he probably went with a different setup with cats.
#63
He responded back..here is what he replied
"High flow cats in the LT connection pipe to factory cat back" he said the mid section is about 10" long and just connects the long tubes to the factory cat back.
#64
And no you don't have your stock engine. You also opened engine up doing rockers. So not stock engine and who knows what else you have opened up for.
#66
Broke engine? Guy still drives it on stock engine. He even went 10.3 on 20s. And boosted to point it was at 9lbs when I went 10.3. Then 11lbs when traded. Passed all compression checks. Stock engine, stock trans, stock headers no weight reduction besides wheels.
FTW..........roller rockers RULE........10,0000,00000.024 hp!!!!
Not like you not mentioning all the work done to cars you know nothing about. Cause if you did know wtf you were doing your would stop riding their coat tails.
