Street Racing & Kill Stories Basic Technical Questions & Advice
I am confused....
Old May 11, 2004 | 12:43 PM
WhiteTXMach's Avatar
Default I am confused....
I thought F-Body's were suppose to be heavy boats, but it comes to find out, my Mach is heavier.... I have a good friend with an LS1, he put down 315/330 before his full exhaust, and has not dyno'd it since then. I put down 305/321, and when we run, he is usually about 1 car ahead, sometimes less, and sometimes I pull him. So we are really close when we run, but if he was making more power than me, even before his exhaust, which now he is making a good bit more power, why isnt he just walking away from me? How an I able to stay with him, and sometimes pull him? He has more power, and weighs less..... we are probably equal drivers... I just dont get it, any ideas?
Old May 11, 2004 | 12:49 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Gearing?
Mach's are running really strong for their advertised horsepower.
Old May 11, 2004 | 01:40 PM
Vendetta's Avatar
F-Bodys weigh around 3400-3500 lbs from the factory... I don't know about the Machs but I know the Cobras weigh right around 3800-3900 lbs. When I got my LT1 weighed I hit just over 3500 with everything in there, so the LS1 probably weighs a little bit less due to the lighter motor.
Originally Posted by SouthFL.02.SS
Gearing?
I have 3.55's to his 3.42's?? I also have 1k more to pull, so we shift around the same time. I always thought he wieghed more than me, and thats why I could hang with him, even though he has about 40 more hp and tq than me.
Old May 11, 2004 | 01:41 PM
I weighed in at 3570 with me and half a tank, he said he weighs in at like 3490 with him and half a tank. My car ( and myself ) need a diet
Old May 11, 2004 | 01:42 PM
Vendetta's Avatar
Another thing to think about is where the power is in the RPM range. LS1s are very much top-end oriented motors, and the mod motor in the Mach 1s are very good lowend cars (they're actually more my style than LS1s are ).
Old May 11, 2004 | 01:43 PM
I have thought about that, and we always run to about 120 or so, from 40-120, or 60-120, usually he pulls me about a car, by 120, sometimes I pull him though.
Old May 11, 2004 | 01:48 PM
Vendetta's Avatar
I have no idea then... you should compare graphs and see who's got more average horsepower. Sounds like you guys have some fun races though
Old May 11, 2004 | 01:55 PM
We sure do
Old May 11, 2004 | 03:55 PM
Dal1as's Avatar
Did he also get LT's? If so he might not have gained much unless he was tuned. I'm guessing he just got a catback which could have him up another 5 to 15 hp and about the same in torque. The weight difference between the 2 cars is minimal. I have no clue how a car with lower hp, similiar gearing, which weighs the same can keep up?
Old May 11, 2004 | 04:51 PM
He got longtubes, O/R Ypipe, and catback.
Old May 11, 2004 | 05:05 PM
unit213's Avatar
Administrator
Jon - My Cobra weighs 3,680lbs without me in it. Not too bad. Not too good either though when my big *** gets in. I should have my g/f start racing people. That around 125lbs saved.
My Z28 weighed 3,400lbs. 3,650lbs with me in it.
Old May 11, 2004 | 05:17 PM
King02SS's Avatar
I dunno about him but I think my longtubes without a tune hurt me on the bottom end. I still have the stock convertor though, so that doesn't help much either.
Old May 11, 2004 | 05:21 PM
Dal1as's Avatar
Then something is wrong with his car or it needs tuned. He should be at around 350 or so hp and 370 pounds of torque. Close to what I'm running and I've raced Mach 1's on 4 different occasions and in each case I pulled them... Hard! 1 even got the jump on me but I blew right by him. Maybe he's trying to race you in 3rd or something. 2nd is good starting gear for a 3.42 geared LS-1 from a roll. My guess is that your friend needs to pick another gear or get his car tuned and checked out.
Old May 11, 2004 | 05:35 PM
Vendetta's Avatar
That's not nearly as bad as people say. But how much of that weight is the huge DOHC mod motor ? We just finished up a headswap on my friend's 98 GT- it was only an SOHC but I was still shocked at how big the block actually is.
Old May 11, 2004 | 05:43 PM
unit213's Avatar
Administrator
The heads are friggin' huge! Not to mention an IRON block. It doesn't seem all that nose heavy though. You know it is though since it takes around 450rwhp to run high 11's. There are guys here running 10's with that much power.
Old May 11, 2004 | 06:29 PM
1gen's Avatar
maybe he just sucks at shifting?
Old May 11, 2004 | 07:04 PM
He went 13.3 @ 109 on his setup, and from a 3rd gear roll I pull him, 2nd gear roll he pulls me. We havent gone from a stop, but I am sure I would pull him pretty good with us both on factory tire.
1gen's Avatar
he sounds like he sucks at shifting if he hasnt figured out that 2nd would be better....
Old May 11, 2004 | 07:06 PM
Of course 2nd would be better for him, but we like to switch it up, go from different power spots for both cars. Gives us a better idea how our cars match up overall, not just peak vs peak.
