Single turbo Supra vs blown Vette - Mexico Racing League
#81
#82
I am happy with it just need to get a better fuel system after what the pump did after and possibly during those races don't want to deal with that.
I will more than likely add meth eventually but am torn on when I do the build if I want o switch it to E or keep it on pump and use meth ... Have a feeling I will stick with pump and meth so that I don't have to do the gas station scramble looking for e85 when I am not in Lubbock
#84
yeah I have talked to him, that is a possibility as well, what are you going to do for tuning with that you have someone you trust for it or look into have him do tuning for you
#86
DONE..
Stock like driveability and enough fuel for 900 rwhp...
I think your car makes decent power for 8-10 psi... An LS9 cam is basically a stock cam... I wouldn't even call that having a cam...LOL
Definitely put meth on it...
Supra did run well though, especially considering he was having spinning/shifting problems.
#87
Go back to a stock fuel pump or an LPE 225 in tank pump. Then run a Bosch 044 external pump on a separate -8an and take it all the way to the rail. Use an A&A Hobbs switch (they are the best ones) to
activate the 2nd pump at 4 psi.
DONE..
DONE..
#88
Go back to a stock fuel pump or an LPE 225 in tank pump. Then run a Bosch 044 external pump on a separate -8an and take it all the way to the rail. Use an A&A Hobbs switch (they are the best ones) to activate the 2nd pump at 4 psi.
DONE..
DONE..
