Bolt on Cobra vs bolt on ls1
#61
#62
Do you realize how ******* hilarious I think it is to make 250+ hp more than me and you only edge my mph by 2??....... and lose in the et department.
What a joke of a car
Don't forget tires. .... Looks like you had a set on. And you yak at me for understating mods. Pot meet kettle. Did it have a intake to?
Just up the shift point a bit and let it run out the bank. A set of headers and a vid converter and it will run 11's. Finish it off to full bolt-on and a couple hundred lb of weight reduction (it's easy to get that out of it ) and you should run mid 11's pretty slick. You will send alot of cam cats packing if you do it right.
Dude even the mach guys on the furd forum did not believe your mph....... it's why you got booted from there.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Yeah if I make more power I'll just up to 27-28 inch tall tire, plus when I have the cam it will have a raised redline....
If i had 4.10s i would be in od by the 1/4 mile.... Hell on the 113 trap i went into overdrive literally 5 feet past the traps!
Thanks guys, appreciate all the compliments!
Btw tire size was 245/50r16.
#63
#64
7 Second Club
Only then, are you on an even playing field with the 10.
#66
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#67
7 Second Club
Meh only the 07s had the heavy balancer. Once you do those mods on a 07-09 car it will be faster then a 10. Then the 10 will be playing catch up and need the same changes. So like I said once the mods start it is the same car. The 11-12 got the aluminum block and the 13-14s got the good stuff ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
That's the troof.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#68
I know derp. Maybe you should re read my post. The 10 is no better as far as performance unless you plan to leave the car stock.
#69
7 Second Club
#70
#71
7 Second Club
#73
7 Second Club
#76
#78
#79
7 Second Club
