Beautiful day to play with Snakes!!! TERMI - GT500 Vs FENIX WS6
Sure. ..... it's pretty easy and very effective. All you need is some .060 aluminum and a hole saw. I used a 3 3/4" hole saw so it was bigger than the pulley by a good amount. You will have to drill the center out for the bolt. You will remove the pulley bolt and put a washer or two behind the guard to keep it off the pulley and then just reassemble it. It's easy. Here's a pic of one I used to run. I put a carbon cover over it.
It's also a good idea to replace the tensioner and do this mod right? 150k miles on it.
Maybe I forgot what your exact build is then, cause I just assumed you sprayed to be a KB Cobra and a 545 rwhp GT500
Replace the tensioner. Katech sells one that's nice. When I went to my new engine it reved so fast it would sling the belt everytime I went WOT.. Katech FTW!!
Ah nice! I think I can handle that. Does the belt usually jump the tensioner pulley to the front? No need to worry about the back part? Also, what size did you drill the hole and what type of screw did you use?
Yea the belt comes off the front. The tensioner guards it to the rear. Just get a little longer bolt with the oe threads for the pulley. Drill the guard till that bolt fits. .....it's like a 3/8's hole.
I ran mine with the guard for 60k and never had a issue again.
Good races LOTB!
#32
It wasn't a KB blower, dude was just trying to intimidate me, and I have beaten that gt500 before, when I was having intermittent issues... and I haven't told anyone my exact build.
#33
HioSSilver***
Do you have more detailed pictures or a step by step on the tensioner mod? I'm starting a thread on thirdhonk.com, for others to see how it's done, if they are having the same problem.
Thanks.
Thanks.
#35
I'm just Fenix fast... you didn't know?
#36
Yessir, a lot of ppl are saying katech... I'll look into it, but really wan to do this mod that HioSSilver did, just to see if it works.
#37
#38
And them Ford Fanboi's can't seem to understand why I am a GM Fanboiiii lol
Awesome runs man. Lil ol LS1 seemed to put an *** hurting on them forced induction 4 valve Ford flagships. (Not trolling, serious....)
#39
