shift sector turbo integra/ TT c6z and my 5.3 rear mount c5z.
Holy **** @ that turbo 5.3 vette!! I normally don't like rear mounts but that one works I guess. Makes me want to go crank my boost and meth up and try to blow that bastard up lmao. Vette moves the hell out. Nasty cars and great runs.
Good runs ZGlass!
Both Vettes rolled the **** out but I gotta say, I am way more impressed with the C5.. Small motor, rear mount that idiots say don't work running toe to toe with a 427, TT..
Simple setup that is dialed in and works! Love it....
(Plus its a C5.
(Plus its a C5.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
That turbo 5.3 c5z is seriously impressive to go neck and neck with that 427 TT man. Properly built cars do so much damage it's so comical to see lol. To me your car is absolutely perfect right now ZGLASS. This is now a favorite video of mine. Thanks for the show!
I actually got him but about 2 feet. top of 4th gear race. i wanted a 45-50 the 60 roll was his race.
I think its damn near perfect too. Im only going for a little more power to not upset the balance of the car. It will spool about the same maybe lose a couple hundred rpms. But will pull much harder up top and peak a little higher. I have eboost 2 and bbg box if need be.
#38
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
#39
no its a box with 4 micro switches to attach to your shifter. hook each micro switch to a different boost setting. so when rowing the gears you activate a different boost setting in every gear 1-4 if you choose that many boost settings.
#40
Ahhh ok. A local buddy with a pretty nasty turbo camaro I thought had that same box...could be mistaken. I just remember when he told me about the scramble button feature, where if your losing a race you hit it and it adds however much boost you programed it to on the fly. I couldn't stop laughing my *** off after he told me about that. ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
