Cammed E85 FBO Coyote vs H/C/I 5.7 CTS-V
#85
No doubt about it. That's how my car was geared until last night. Me and the ol' man pulled my center section out. Was running a 3.89 with a 28 inch tire. Which the effective ratio is around 3.71. Dropping the diff off today at Moser to get 4.30's installed. Before the 3.89 on a 28 was basically like you just posted. Third gear in my car feels a little flat compared to 1st and 2nd. Effective ratio will be about 4.12 now. I am running a hopped up 383 in a lighter car. Just hoping I can stick first gear once I go to a 295/55 mickey. Then it will be just what I want I think.
#86
Wish I could swap gears and still keep the strong rear diff.
with 7k redline and 325/30/19 I'm hitting 60 in 1st, 90 2nd, 120 3rd, and 160 in 4th.
Came up with a solution though. Just keep adding power until 3.42 is optimal.
#87
That is always a option. I don't plan on adding power so I am optimizing the gearing at this power. There will still be about 10mph left in the quarter running 4th if I ever wanted to spray it a little. Most likely won't happen.
#88
Don't get me wrong, I'd swap gears if it was possible. Definitely not swapping both transmission and diff to weaker base C6 version just to swap gears, though.
#90
Gearing is funny. No tq havin motors need it. Solid tqy motors don't.
Gear mostly helps from a dead stop with traction. With out traction it's not that benificial. Gear the car for the speed you intend running.
With gears I could see your 1st gear being really short with your trans. I think the spreads are a little better with the fcar stuff.
I had a couple gto t56's I thought about using once but the gearing and calcing it just didn't seem to work out for me.
HHHmmm....No zo6 gears?
#91
#92
Hell no! That car is built to go fast. A f body with rattles makes you want to stay slower lol. My Scat Pack cruises 130 smoother than 50 in my Camaro lol.
#97
I could see with how aggressive the gearing in the tranny is that a lower rear gear like that could be the happy medium. I think 4.10's are and obviously always been the happy medium on a 26" tire for a 6 speed 4th gen with basic mods to full heads cam and spray. After that you jump up to a 4.30 with a 28" then you are good to around 140 up around 7krpm in 1:1. I am talking quarter mile racing though.
#99
#100
If having you stumble over your words when you try to pass your opinions off as facts makes me a low life, then yep! Further proof that you'll sit on anyone's dick who gets off to LS anything, in this case - Misty We all knew you'd stoop low but this is surprising, even for someone as classless as yourself.
I think you're just salty about my location information
