Ls1 vs 3v and coyote
#42
Thanks guys, all the suggestions and help is greatly appreciated...I've been doing a ton of research to figure out what I'd need to get to my goal but having people who has been there and done it is priceless, also 85$ for a trans cooler and that's awesome will definitely pick one up , 200-400 for headers Is also great. Quick question though y or X pipe? And came size?
I also run this additive called lubeguard in my stalled transmission. It will keep your fluid 20-30 degrees cooler. I've tested it out and it's legit.
#44
I'd recommend the TSP 228R cam, or the Torquer V2 cam. Those are medium sized cams with plenty of power. And I think Y pipes sound better IMO.
I also run this stuff called lubeguard in my stalled transmission. It will keep your fluid 20-30 degrees cooler. I've tested it out and it's legit.
#45
#46
And I can probably search this but how hard is it really to change a cam, I've never done it but I'm good with my hands my cars usually never go to a shop for repairs.
#48
And you'll probably want to replace your stock lifters with new stock ones, when the cam goes in.
#49
Yeah definitely, my car has 146000 miles on her although she runs just as strong as new.
#51
Thanks guys, all the suggestions and help is greatly appreciated...I've been doing a ton of research to figure out what I'd need to get to my goal but having people who has been there and done it is priceless, also 85$ for a trans cooler and that's awesome will definitely pick one up , 200-400 for headers Is also great. Quick questiodn though y or X pipe? And came size?
New valve springs
New push Rods
Have to do the timing chain while your there
Search a lot man
#53
True, I forgot about the pushrods. You really should just get aftermarket heads too, since the stockers have to come off anyway lol.
#54
LOL I'm sitting here thinking about it now.....might as well get heads although I'd have to wait a while....if I didn't have to pull the heads off I'd be confident in doing it myself, but if they're coming off Im probably sending her to a shop
#56
I definitely understand.....even if the heads do have to come off I'll probably still only do a cam heads are expensive and so is shop time, lol besides full bolt on f-bodies are plenty quick and with a cam I'm sure I'd be satisfied.
#57
Absolutely. Texas speed has a head porting service for 750$ thst includes the 660 lift springs. I think it's worth it considering the springs are 200$ alone
Just something to consider
#58
I've been reading and watching videos, I'm actually pretty positive I can do it myself
#59
I went with a y-pipe, soon switched to an x pipe. got the local shop to do a set up for me cost about $500. plus $85 for the xpipe and a few hundred for nice mufflers. its all in how much you wanna spend and how you want it to sound. performance wise the difference is small between the two.
