Poppa(S550 Mustang) vs 6gen SS at track
#41
Not knocking you. Just the way it is.
Be closer than it is....and it's apparently closer than they want. A a8 on a tire would outrun poppa by these results
Thanks. They do run good.
You failed to notice the 2mph trap difference between us. My lead would have just grown through the 1/4 I have also run 7.6 in the 1/8th..
Its possible... would have to actually do the run. I am putting more power down to the wheels and trap about 2mph more. Looks like based on that his is a 115mph car in the 1/4. Not bad at all stock though.
#42
I will be sure to get the requisite gold chain to go with the Vette.
I just like the modern autos now man. With the manual modes and paddle shifters you can have just as much fun in the twisties as a manual car imo.
This manual car ran good. at a 1/4 mile track I would put him at 12.2-12.3 which is what the faster manual cars are averaging. He drove it well. Second run where he spun a little, he said he was nervous.
I for sure would not lay bus lengths on him from a roll, but my 2mph advantage would show for sure. I would estimate a couple car lengths 40-140. He ran good. Much props to GM for those cars.
Love you too Jakeypoo!!!!!!!
I was surprised too at how well it got off the line. I really wish we could have got another run in. After our second run, I was going to let the car sit for a little bit, and he was going to run one more time hotlap, then him and his gf had to leave. So no time to get a third run in. He was good people tho... we just bullshitted about both cars.. good times.
Okey Dokey Hammah!
My best of the day was 7.80 on my first run of the day before he got there. His best was 8.08. That is .28 difference... almost 3 tenths mang. A tire would have got him another tenth, tenth and half on the 60ft. Definitely would have been closer, but I would have still got the W. Honestly, if one or the other sucked at the tree, the other would get the W.
As far as mph goes, with the conditions today, I would think he would run 115 range in the 1/4. I have run 116+ in the same conditions. Still would have the edge mph wise. But not taking anything away from the car.. I am modded, he is stock. The 5.0s stock have ground to make up right now to keep up with the 6gen SS. No secret there.
I honestly think his car is a strong running example of the manual 6gens... and he could definitely drive... drivermod was there.
I hope to be able to run an A8 car soon... because possibly in the next couple of weeks, a stall will be going in the car. Thos 7.6-7.8s are going to turn into 7.1-7.3s without any other changes.
Okey Dokey Hammah!
How so? You went like just over .1 faster on your best run of the day vs a stock car. A tire only would give him the w. Especially if he went with a shorter tire like you.
Actually that would likely give the camaro the w.
Hhhmmmm.....you're not looking at his gear splits. He shifts to 3rd at 80mph which is likely hurting his 1/8 mph since 3rd runs out to 110. My bet would be if you woulda been on a qtr track today the mph woulda been closer at the end of the qtr than the end of the 1/8.
#43
#44
#45
Buddy of mine went 7.2s with his 15 GT. He had long tubes, but was on 93 tune. Was running 7.7-7.8 before it. I guess it may or may not pick it up.. we will see. I prefer running 1/4... but that damned 2hr drive.... and now they run 5pm-11pm instead of 11am-dark like they were.
#47
#49
On good runs, yeah. No secret that drag radial A8 went 11.7 hero run.. and buddy of MMs in Florida is running 11.8s tune/tire. Would be some very close races.. which is what I like. After my stall though, a manual SS would need some more bolt ons, and an A8 would need a stall too. Either way, makes for some fun racing.
#51
The problem i see here poppa is you keep comparing your times to a stock sexgen. A sexgen with similar thought out mods as you will put you needing a converter to keep up. Think about it.
-100 lb with some of it alot of it rotating like you
Catback....hp ?
E85....seems to be about 30hp
Drag pak with a dr
They don't seem to need much for suspension but lowering it a little could help mph a little.
6gen stands to pick up .5 with just those mods. And that's probably conservative.
Catback....hp ?
Drag pak with a dr
#52
So in turn a drag pack a8 would run high 11s all day in this same area and same night. Right in line with you.
E85 and tune would go right near the ~.5 stock gap imo. Other than the 35rwhp increase you got removed TM and quicker firmer shifts. Suspension mods and cat back may help a touch as well. At most with bolt ons I can see the 5.0 closing the gap a tenth or two.
I just don't see how they will run equal with equal mods. Not on the same track same day with equal launch. You had trouble with a stock tire manual bro.
Not sure if you've been looking lately but the 6gen doesn't need negative DA to hit 11's. One has done it in low positive DA. We have also had a few lately come very close in +1-2000DA. The latest was a guy who just ran 12.2@115 in 91 degree heat and a 1.9 60 ft. Bone stock. He would get the 11 second slip with just a better launch.
#53
#56
I'll have you know that I'm an awesome bench racer!!!
I get it, but I honestly do at least run 50-75+ times a season at the track and street race too... So does that make me a certified bench racer, or just another srk idiot? Got it, srk idiot lol
